itunes question
7 replies [Last post]
PeterDs
PeterDs's picture
I am on a network (ethernet). the itunes and all the music, playlists are on a power mac (powerPC), and I want to play the music thats on this mac from my Windows xp computer (both are connected to the same network, i can very well see the shared files and folders in the mac in the xp machine).
I have shared the music folder in the mac (went to system preferences/ shared and did it)
Problem is, I cannot see any of the playlists in the XP. Is there a way I can do this? I really dont want to copy all the same music into the XP machine, just want to play when I want to.
ifor
ifor's picture
Online
ifor
This might not be the best answer, but I think it should work.  On the horrible PC thing, go into iTunes preferences and set it so that added music is not imported into iTunes.  Then select Add to Library, again on the PC, and point it at the iTunes music folder on the Mac.  You can now build playlists in iTunes on the PC from music files that are only stored on the Mac.
__________________
Source 1) "Inspired" Manticore Mantra turntable c/w Rega RB 301 arm, Goldring 1042 MM Cartridge, Graham Slee Reflex M phono stage, Graham Slee CuSat 50 interconnect
Source 2) Cyrus CD8 SE CD player
Source 3) iTunes (ALAC), iMac, Devolo Homeplugs, Apple TV3, Toslink, Arcam rDAC
Source 4) Technics SL-7 linear tracking turntable.
Roksan Kandy L3 amp, Spendor A5 speakers.
Other rooms: more Airport Expresses and Homeplugs with Denon AV system and Denon Mini system.
ifor
ifor's picture
Online
ifor
__________________
Paul.
Paul.'s picture
RE: ifor
If you open iTunes on both machines, does the mac share not show up in the left hand sources column in iTunes on the XP machine? If you enable home share on both machines you can copy too and from the different iTunes.  Assuming you can install a new enough version of iTunes that is.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
busb
busb's picture
RE: itunes question
Make sure Home Sharing is enabled for all instances of iTunes & as Paul states, you should have a header called "Shared" in the left column with another computer's name listed below it. If you also have an iPhone, iPad & or iPod, download Apple's "Remote" app that will list any instance of iTunes that have Home Sharing enabled. The Remote app will also control an AppleTV & iTunes Match.
__________________
"The optimist proclaims that we live in the best of all possible worlds - the pessimist fears this is true."
James Branch Cabell
_________________________________________________________
MAINApple TV2 & iTunes Match, CA Azur 751BD or Panasonic P42V20B into audiolab M-DAC, feeding a Primare A34.2 via XLRs, 2x 5m of Atlas Ascent 2 firing up Totem Arros.
ON THE HOOF: iPhone 4GS/Sennheiser MM450.
Another interest:
http://www.flickr.com/photos/busb/
PeterDs
PeterDs's picture
RE: itunes question
Actually I was trying to access the itunes playlists in the mac NOT from itunes in XP. But from VLC player. I guess itunes ha to be installed first. I will try it thanks guys.
PeterDs
PeterDs's picture
RE: itunes question
OK I installed itunes in the XP machine and voila! I can now see the songs in my mac in my XP!!
BUT. I can only see them under "SHARED" (Apple's Library) and the songs are all mixed together, in one list. If only I can organize them into playlists, I will be a hapy bunny...
(The "Library/Music" folder does not have anything showing in the XP machine, as yet)
PeterDs
PeterDs's picture
RE: itunes question
Is there no way to Import the (existing) playlists from the remote machine (powermac, in my case)? I can see all the music in the mac in the XP computer, but there are no playlists or anything, just all the music in a list.
