Sony bdp settings. Help please.
9 replies [Last post]
RobinKidderminster
RobinKidderminster's picture
Online
Advice please. And I thought I understood AV! I wish my amp to decode but wonder if my settings are correct. Audio HDMI @ auto DSDoutput mode @ ON BD audio mix @ OFF DD coax/opt @ downmox PCM DTS coax/opt @ downmox PCM DTS Neo6 @ off Downmix @ stereo Cheers
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
RobinKidderminster
Online
RE: Sony bdp settings. Help please.
Hopefully someone can help after a hard day at work?
__________________
f1only
f1only's picture
I have the Sony BDP-S790 so not sure if the Audio Properties will be exactly the same, they look similar to the old Sony BDP-S380 i had from memory.
 These are my settings & it Bitstreams to my A/V Amp.
Audio (HDMI) - Auto
DSD Output Mode - Off
BD Audio MIX Setting - Off
Dolby Digital / DTS - Bitstream
DTS Neo:6 - Off
Audio DRC - Off
Downmix - Stereo
Regards ...
RobinKidderminster
Online
Many thanks f1. I guess we both wish the amp rather than bdp to process. A couple of settings for me to check
__________________
f1only
f1only's picture
Hope it is some help. By the way the DSD setting is just to set the output audio mode for the HDMI when playing SACD & i cant tell you what effect this has as i do not own any SACD's.
The amp, as far as i am concerned, is built to do the processing so should be better at it.
Regards ...
RobinKidderminster
Online
Downmix / stereo was one which puzzled me from the user manual. I think the others, where we differ, only apply to optical/digital coax and as you say the save setting. Is it only me that finds these settings confusing? Cheers again f1.
__________________
RobinKidderminster
Online
Realizing my bdp is also connected thru AV2 I need to check some other options now!
__________________
RobinKidderminster
Online
Av2 not great. HDMI front&sub is best. Any other be settings please post. Cheers
__________________
chrisup
chrisup's picture
Hello Robin,
I have a Pansonic DMR BWT720 and when I select SOUND I am able to chose DIGITAL AUDIO OUTPUT  then I can select either Bitstream or PCM for all Dolby and then all DTS. I triead both Bitstream which my Onkyo 905 decodes and PCM which my Panasonic decodes and my Onkyo says MULTI. I prefered PCM with my B&W 685 Theatre speakers.
I hope this helps someone else from Kidder. I like your photos and room treatment.
Best Wishes
Chris
RobinKidderminster
Online
Thank you kind sir. Not at home to experiment right now but will keep you informed. Cheers
__________________
