5 posts / 0 new
Last post
Juzzie Wuzzie's picture
Last seen: 2 years 5 months ago
Oppo 103/105 + Harmony/Logitech Remotes
RE: Oppo 103/105 + Harmony/Logitech Remotes
Question was whether anyone had successfully set up their Harmony Remote to control the Oppo as a processor (say with Sky feeding in via HDMI)?  Any tricks or techniques.  I found the Oppo would not switch inputs properly when pushing the "Activity" button and especially so if there was a disc in the machine from start-up (i.e. Activity = "Watch Sky") it would just start playing the disc.
Help!
JC
pete321's picture
Last seen: 2 years 6 months ago
I use my 105 to upscale Sky via the rear HDMI input. When setting up my Harmony One, I included the Oppo command for 'input', left a few ms gap and then '3' (HDMI Back). This automatically switches the Oppo to the correct input on start-up.
Gasarn's picture
Last seen: 3 years 1 month ago
Go to the Oppo Device in the Harmony software. Select settings > adjust inputs.
Select Method 4.
"Remote button displays source inputs menu": Input
"Remote button confirms the source input": None
Bluray Player: 1
HDMI / MHL In-front: 2
HDMI In-back: 3
ARC..HDMI out 1:  4
ARC..HDMI out 2:  5
Optical In: 6
Coaxial In: 7
USB Audio In: 8
Gasarn's picture
You can select if the CD should start automatically in the Oppo settings menu.
Log in to post comments
