7 posts / 0 new
Last post
gsyx123's picture
Last seen: 6 months 23 hours ago
BT HomeHub2 and PS3
Has anyone had trouble connecting their PS3 to the new HomeHub2 wirelessly?
I rcently swapped my old bt hub for one of the newer ones. To begin with i couldn't even get it to work wirelessly with my laptop, now i've fixed that problem it will not connect with my PS3!
I have tried to set it up manually (limited knowledge here) and still no joy. My PS3 connected first time with the old hub, so what am i doing wrong.
Regards
Graham
LG 55EF950V, Pioneer SC-LX59 AV Amp, B & W MT60D Surround Speakers, SkyQ, Logitech Harmony Ultimate remote
Anonymous's picture
Re: BT HomeHub2 and PS3
I'd suggest reading the below which may shed some light, before calling BT. It's a BT issue rather than your PS3, I imagine.
http://www.beta.bt.com/bta/forums/search.jspa?objID=c3&q=ps3
gsyx123's picture
Thanks Richard, makes for interesting reading.
Looks like another hour on the phone to BT technicalCrying
Anonymous's picture
What bugs me is that its BRITISH TELECOM but tech support is in India!!!!!! drives me crazy!! it takes about 5 mins for them to take your name!
i.e. if you they had a UK call centre you wouldn't have to spell out your name JOHN.
I think it's shocking and very sad that we have to put up with this!
aliEnRIK's picture
Last seen: 10 months 1 week ago
I dont have one so Im kinda guessing here. But going into the PS3 settings you need to have a NAT 1 or 2. if it says 3 then the protection built into the router is blocking the signal
You need to log into the router using your PC and either put the PS3 outside of the NAT, or allow all the necessary ports for the PS3 to work
bigblue235's picture
Last seen: 2 years 8 months ago
I have a Home Hub 2, which I thought would be swapped out rapidly, but I really like it. I've had no problems at all with it.
That said, I tend to connect stuff up with ethernet cables if at all possible, and I think my PS3 might be hooked up that way. I've got various other stuff hooked up wirelessly though, haven't had any issues.
The NAT problem that alienrik mentions may well be the issue, I had that problem with a Zyxel router I got from a different ISP. The Homehub menu http://bthomehub.home is fairly straightfoward though. Have you tried adjusting the appropriate settings from there?
Good luck!
gsyx123's picture
Sorry, but i don't understand what 'nat 1 etc' is. However i have managed to sort it. As i mentioned i only have limited knowledge of these hubs, but i managed to fix the problem by opening up the hub manager, going into the settings, and changing the channel from 'automatic' to a specificly numbered channel.
I don't know if it will cure anyone else's problem connecting to the ps3, but it worked this time.
thanks for all the help though guys.
Log in to post comments
