smart tvs and mkv files
12 replies [Last post]
celsius
celsius's picture
hi all
do any of the current models of smart tv's with dlna playback mkv files?
i am looking at getting a new tv max size 37 inch as mine has a few problems currently using an old pc with xbmc but wife says it has to go(doesn't fit in ) all my bds and dvds stored in mkv format and have no desire to convert them all.would prefer to have just one box to do it all budget approx £700
__________________
naim unitiqute,b&w cm1,i5 silent pc, boxee box,synology ds1812+ with 4xwd red 3tb and 2xwd green 2tb
panasonic 32lxd60
grado sr125,klipsch image x10,ipod classic 120gb
Oldboy
Oldboy's picture
Online
RE: smart tvs and mkv files
I can't name a single tv that supports MKV...both my Sony 46HX853 and Samsung UE32C4000PW (bedroom tv) don't support MKV and is the reason I bought one of these:
http://www.amazon.co.uk/Western-Digital-Streaming-Media-Player/dp/B005NY...
It's such a small box that it's easily hidden and allows me to watch all my HD MKV files with no issues, I simply couldn't find a one box solution and that little WD box has been the ideal solution as it's so tiny. I think you will really struggle finding a tv that supports MKV over DLNA or even USB.
__________________
Sony KDL46HX853, Yamaha RX-A2020, Dali Zensor 5 5.1, Panasonic DMP-BDT500MR, Marantz CD6003, Marantz PM6004, Beresford TC-7220 MKII, PS3, Xbox 360, QED Silver Anniversary XT speaker cable, Wireworld Chroma 7 HDMIs, Chord Crimson Sub and RCA, Chord Superscreen Mains Cable
daveh75
daveh75's picture
The trouble with MKV is its a container format, support depends on the video/audio codecs used within
__________________
Paul.
Paul.'s picture
Samsungs from 2012 will play MKV files, you can even install plex and stream from a PC or Nas.  As Daveh75 mentions though, MKV is a bag of hurt.  It is a container format with over 200 different codecs inside, so inevitably you will find combinations of codecs that don't work with your TV.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
Paul.
Paul.'s picture
Panasonic ST/GT plays MKV too off the top of my head, but can't think of any more.
__________________
Oldboy
Oldboy's picture
Online
My GT30 never played MKV files so I presume the GT50 will?
__________________
Paul.
Paul.'s picture
Correct, sorry I thought I had put a 50 on there but apparently not!
__________________
Oldboy
Oldboy's picture
Online
Thanks for the info Paul, it's good to know that MKV is actually getting supported by tvs now. I had no idea about the complexities of the format either but then it's not my field of expertise and is beyond my knowledge. Is MKV actually better avoided then even if it means converting?
__________________
Paul.
Paul.'s picture
If I was ripping something, I would tend to avoid MKV just becuse not everything plays it.  Most people who rip something in MKV will rip with a sensible codec, but you may occaisionaly find open source types ripping the audio in Vorbis for instance (which many tvs cant handle even with MKV support).  MKVs with video in Mpeg or h.264 and audio in AAC or MP3 for instance will be fine.
__________________
celsius
celsius's picture
thanks for the replies i have found out that panasonic tx37 e5 or something similar supports mkv but will phone panasonic to confirm
__________________
panasonic 32lxd60
lokusai
lokusai's picture
Morning!
I have a Panasonic (TX-L37DT30B) and it streams MKVs pretty well from a Synology DS212j.  It occassionaly stutters a little but not often (and does the same with MP4s).
From my experience, you'd still be better getting a dedicated media player as smart TV's can be pretty slow at loading file lists etc. when searching for a movie within a large collection.  Having said that, I haven't tried the plex app that's available on some LGs and Samsungs, so that might help.
__________________
Paul.
Paul.'s picture
Yep, agree with that.  Plex is fine on the Dual Core tvs but can be sluggish on lower spec tvs.
__________________
little_dee
little_dee's picture
I've just bought a Panasonic 50" UT50 http://tda.panasonic-europe-service.com/docs/2z51014126z3z33ea7z656ez706...   from John Lewis which has no problems playing mkv files either streemed from my PC (XBMC) via ethernet or from a USB Stick. In fact it has so far played pretty much any format I've tried. The link above will give you the full list of supported formats & it is quite impresive. It's a great TV, granted it is bigger than you specified but well within your budget @ £599 with a pair of free active 3D glasses (worth £100) if bought before the end of this month.
