19 posts / 0 new
Last post
bigboss's picture
Last seen: 1 day 4 hours ago
7.1.2 or 7.1.4 for 16 feet viewing distance?
I met with a home cinema installer for my new house (ready by December). The living room is 12'4" X 16'1".
He suggested using the top wall for home cinema (TV with drop down acoustically transparent projector screen and in-wall speakers from Monitor Audio Trimless 200 series).
Effectively, that gives an almost 16 feet viewing distance. I'm thinking of going for an 8 feet screen.
My original plan was using the other wall, with 12 feet viewing distance. So 7.1.2 speakers for Dolby Atmos would've been ideal. But with a 16 feet viewing distance, is 7.1.4 setup better?
The fronts and centre will be in-wall speakers and the rest will be in-ceiling. I'm also thinking of going for MA in-wall sub.
Going for 7.1.4 would also mean opting for Yamaha RX-A3040 instead of 2040.
Thoughts?
davidf's picture
Last seen: 1 day 3 hours ago
I would go for two pairs of
I would go for two pairs of in-ceiling speakers for that viewing distance. I'd think about one pair if the viewing distance was under about ten feet.
the little audio company, jewellery quarter, brum
audioquest / audio technica / bluesound / chord co / cornered audio / golden ear / harman / innuos / jbl / kef / moon / ophidian / primare / revel / svs
bigboss's picture
Thanks David! I did suspect
Thanks David! I did suspect that would be the case.
davidf's picture
My veiwing distance is about
My viewing distance is about 9 feet, and I'd only put one pair in that sort of space.
FunkyMonkey's picture
Last seen: 2 days 19 hours ago
I recently installed 7.1.4
I recently installed 7.1.4 for a 13 foot viewing distance. It just looks right in the ceiling.
100inch screen. That's 8'4"
bigboss's picture
Thanks for your replies! 7.1
Thanks for your replies! 7.1.4 it'll be then!
They are laying the
They are laying the underfloor heating and screed in next week or so, so another month before I can test all the signal paths. Exciting stuff. Glad someone else is on similar journey. Thumbs up.
stavvy's picture
Last seen: 3 months 5 days ago
Looking forward to hearing
Looking forward to hearing what you think of atmos in a home set up! Smile
Pioneer PD30S SACD player, N30S Network Streamer, A50S Amp
Bowers Wilkins 685
buzz_lightclick's picture
Last seen: 2 weeks 5 days ago
bigboss wrote:
Thoughts?
You seem to be set on a Yamaha receiver again.  I guess you have demoed the likes of a Pioneer Sc-lx87 (though the 88 will be out by the time you buy), Arcam AVR750 or Anthem Mrx710 etc?
Pioneer KRP-500A, BDP-LX88, Monitor Audio Apex, Silver FX, Yamaha ceiling speakers, B&W PV1D, PS4, Sky+HD
bigboss's picture
Thoughts?
Of the AV receivers you've mentioned, only Pioneer LX88 supports Dolby Atmos. I personally didn't like Pioneer-Monitor Audio combination (bright for my taste). Yamaha partners beautifully with Monitor Audio when I demoed it with Monitor Audio Silver series (on which the Trimless 200 series is based).
RobinKidderminster's picture
Last seen: 1 month 3 weeks ago
Is your seating against the
Is your seating against the back wall? Need I ask more?
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
bigboss wrote:
Thoughts?
Ha - good point. I guess I meant the next variant of the other models that does support Dolby Atmos!
Personally I've never found Pioneer and Monitor Audio to sound bright, and I think with the LX87 it was found by reviewers to be less bright than previous models in any case, so I expect the 88 to follow in a similar vein.
ideal av's picture
Last seen: 2 weeks 4 days ago
you seem set on MA`s
you seem set on MA`s indecision
i`d definatley recommend fitting 4 inceiling speakers in that distance, I can`t say i`d recommend fitting those though crying
bigboss's picture
Yes. I've been wowed by the
Yes. I've been wowed by the Silver series, and Trimless 200 is the in-wall & in-ceiling version of Silver series. Smile
MK is way beyond my budget.
Due to the seating position, and the fact that Yamaha RX-A3040 doesn't support 7.1.4, I've decided on 7.1.2. Will be a lot easier to install as well.
Perhaps a reason to consider a different receiver after all?
bigboss's picture
The only true 11.2 receiver is an Onkyo which runs hot. Not suitable for my install. Besides, it is very expensive.
If you look at my other thread (New house, new plans), the speakers at the back were getting very crowded with side surrounds, rear surrounds and rear Atmos speakers all confined to small area. The Atmos speakers will end up being on the proper ceiling instead of false ceiling, making it a more complicated install and leakage of sound to the room above.
Pages
Log in to post comments
