Pioneer SC-LX85 update available?
Just plugged my new 85 into the mains and ethernet port to make sure all is working before I go ahead with swapping this out with my 72.
Installed the software that comes with it and one of the options is to check for updates to the receiver and or the software it's self.
The software is up to date but an update to the receiver was available to download, I have downloaded said update and extracted it to a folder.
I cannot find anything on Pioneer's website or anything in the zip file to say what it does, can anyone at WHFI shed any light on this before I complete the update.
Any help at all available please.
Michael while your waiting for someone that knows to reply..... try e-mailing pioneer support and ask them the question. Not sure how long they take to reply but they should get back to you.
Clare or Andrew,
Can you check with Pioneer, the downloaded file is called AVR_12_0202.
translated from a German forum
Firmware: My LX85 says "no update", but the AVNavigator has found one! After untzippen called the thing "AVR_12_0202.mem" .. I do not know yet what that is for an update, I'll look at me the times
EDIT: After I had packed on the SD CARD
, and tried to update via USB, it says to me "is the same as you've got"
So no update - I would have also wondered if the AV is not the Internet, but the comic AVNavigator SW
Thanks v1c, I have not had much time these last few days to find out anything myself.
I will probably leave this alone and just set the amp up at the weekend.
I have just used the option from the amp menu and this says it is up to date, so I will leave it alone.
Still setting the amp up.
- Login to post comments
Clare or Andrew,
AV System - Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
