62 posts / 0 new
Last post
bigboss's picture
Last seen: 12 hours 33 min ago
What ultrabook?
I'm thinking of getting an ultrabook. My requirements are:
1) 13 inches
2) 512GB SSD storage
3) No optical drive
4) Decent battery life
5) Touchscreen
6) Ultraslim profile
I can't find anything decent. I can get a 13-inch MacBook Air with 512GB SSD & 8GB RAM for £1305. I can't believe there's no competition for it on features & price. I already have a MacBook Pro, so want a Windows 8.
Paul.'s picture
Last seen: 1 week 4 days ago
RE: What ultrabook?
If you can stretch to 14" you could look at that carbon Lenovo?
bigboss's picture
RE: What ultrabook?
Yes, I've checked that. That's the closest I've found matching my requirements. But only 256GB SSD unfortunately.
scene's picture
Last seen: 6 days 1 hour ago
RE: What ultrabook?
The Dell XPS14 has a 512 SSD option - but it's 2.1kg and £1460!!
EDIT: And come to think of it, when I looke a month ago, I'm sure the Toshiba Portege Z930 had a 512GB SSD option - that I can't seem to find anymore. I have an older Toshiba portege that has lasted 6.5 years now.
AV: Marantz SR7009; Monitor Audio RS-LCR, Silver 8i, RXFX; BK XXLS400 Sub; Pioneer KRP500a; Sony BDP-S760
HiFi: Arcam A85; AE Compact 1; Arcam DV79 (as CDP), ProJect Debut II
cheeseboy's picture
Last seen: 1 day 21 hours ago
RE: What ultrabook?
might be easier to buy one with the spec you want and a small ssd, then just buy a 512gb ssd and stick that in.
professorhat's picture
Last seen: 1 year 6 months ago
RE: What ultrabook?
Buy a Macbook Air and install Windows 8 on it using Bootcamp / VMware Fusion / Parallels?
EDIT - ah, you want a touchscreen
The owls are not what they seem...
bigboss's picture
RE: What ultrabook?
Well, touchscreen only if it's Windows 8. To be honest, I am mulling over the option of having 2 MacBooks ( while my Windows 8 next to me is stuck in a restart loop  |( ) - the MacBook Pro is my wife's. I just feel that if I have 2 systems at home (Windows & Mac), I will have the flexibility of both ecosystems. Besides, I can foresee compatibility problems when I want to use it for work purposes (NHS). Apple makes beautiful hardware. Lenovo ThinkPad runs it close.
bigboss's picture
RE: What ultrabook?
That's an option! Would that not void manufacturer's warranty?
bigboss's picture
RE: What ultrabook?
Looks nice, but it's still 2.1 kg!
How is Toshiba? A friend of mine hated it, as it broke down a few times.
bigboss's picture
RE: What ultrabook?
I was looking forward to Asus announcing more models in its Zenbook series, but they haven't done so as yet.
RE: What ultrabook?
Windows 8 runs quite happily on my Macbook Air as a virtual machine in VMware Fusion. You get the best of both worlds as you can still run PC apps, but VMware Fusion ensures Windows supports all the normal Mac gestures i.e. two finger scrolling, three fingers to move windows etc, plus four finger swish to move from the Mac desktop / full screen apps to the VMware Fusion version of Windows running full screen. It can even make Windows apps appear to be running as normal Mac apps, though I've found this functionality to be a bit flaky personally (though that could just be the dodgy work apps I use!).
The only thing I'd recommend if going down this route would be to spend the £80 to up the RAM to 8 GB so you can assign Windows enough RAM and not affect your normal usage of Mac apps.
Scissor_digits's picture
Last seen: 5 months 3 weeks ago
RE: What ultrabook?
Sony VAIO T Series 13 Ultrabook
On Sony's website the standard version is £619 but when pimped up to your spec it's £1,189
Your requirement for 512GB SSD means you'll be lucky to get anything below £1,000
dreddric's picture
Last seen: 3 years 2 months ago
RE: What ultrabook?
I am really happy with my Toshiba Z930 (i7, 8GB RAM) and it is so light to carry, but it is not Touchscreen. It initially came with a 128GB mSATA SSD which I upgraded to 256GB, I don't think a 512GB mSATA SSD is commercially available yet? If there is, no doubt it will be very expensive!
The Toshiba U920T sounds similar to what you are looking for, its a Window 8 hybrid (laptop/tablet), but again only with 128GB SSD and not sure how easy it would be to upgrade.
cheeseboy's picture
RE: What ultrabook?
nope, shouldn't do, that's one of the points of having upgradable parts Biggrin
bigboss's picture
RE: What ultrabook?
Now that looks very nice! A little beefier to my liking, but not bad at all. Will go & check in store.
bigboss's picture
RE: What ultrabook?
:cheers:
Pages
Log in to post comments
