more 'snake oil'
431 replies [Last post]
Thompsonuxb
Thompsonuxb's picture
Do surfaces really make difference to the sound a CD player/DAC or an amp makes.(Should I include PC's/MAC'S too) Glass, wood, plastic does it affect the sound, I know back in the day I placed a sponge from an old settee under my turntable to reduce vibration, but todays tec is less affected than turntables. I mean anyone hear have squash balls cut in half under their amp or CD player feet or maybe a iso plate or anything like that.... or is it more nonesense?
CnoEvil
CnoEvil's picture
RE: more 'snake oil'
Here is what Lavardin have to say about it ("What is the best rack to put the amplifier"):
http://www.lavardin.com/lavardin-faqE.html#support
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
MajorFubar
MajorFubar's picture
There's not one irrefutable reason I can think of why HiFi should be affected by the substance used to make a support, only the rigidity or lack of it.  Yet I have always preferred the sound of my HiFi when it's supported by solid wood rather than by glass or metal racks.  I can give absolutely no credible reason why there is a difference.
__________________
Main gear: Mac Mini > HRT Streamer II+ > Marantz PM66 KI > Mission 794
Also cluttering-up the place:
Thorens TD160 no cartridge; Marantz CD63 mkII KI; Technics SL-P777; Cyrus 2 + PSX; Cyrus Tuner; Nakamichi DR-1
SteveR750
SteveR750's picture
I'm sure I still have some of those magical black triangles from Peter Belt somewhere. Must dig them out and convert my DAC into a worldbeater!
__________________
JRiver MC17 -> Cambridge Audio DACmagic+ -> Roksan Caspian M2 -> ProAc D18
chebby
chebby's picture
I think they were adhesive foil triangles and they were put on the front cover of some hi-fi mag once (probably one that Jimmy Hughes wrote for) as a free gift. I gave mine to a friend's daughter who liked coloured stickers. I'm pretty sure that was well over 25 years ago.
I am amazed that anyone has kept them for that long.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
ellisdj
ellisdj's picture
Check out the Big Question in the latest What Hifi Mag - Nov Issue
I was part of a 3 man blind test in the What Hifi test rooms.
We thought we was going to be hearing 3 different systems - same speakers, same cables.
We heard 3 different styles of song many times and all 3 of us could clearly hear differences along the way - some smaller than others - some in presentation etc.
Now it turned out the only thing being changed was the surface the cd player was sitting on.
All 3 of us were completely shocked by the news and that has changed my opinion on the matter forever!!
Now bear in mind the what hifi test room is a purpose built, acoustically treated room - that lets you properly hear the system you are listening to.
In a non acoustically treated room - you hear the room more than you hear the kit - ie. the room influences and skews the sound so you do not hear exacty what is coming from the speakers -  so therefore the differences in products like these are often called snake oile - wrong the room you are in / the speaker position / your seating position is not letting you fully hear the differences they can make
I am now embarking on a room acoustics project to improve my listening room.  My cousin has already added acoustic panels to his walls and the difference it has made in his system is huge!
I am waiting in a new sofa then I will be doing mine and cannot wait,  I have also ordered a Hi Fi Racks Podium - but thats for aesthetics, function and size as much as sound.
__________________
Meridian G61R, HD621, G55, MC200, MS600
Pioneer LX5090 Calibrated, Marantz UD7007, HIFi Racks Podium Reference
Monitor Audio GX100, GXC150, Apex A10, BK XLS400 (set with hard knee house curve)
Graham Slee Spatia (SC) Graham Slee Cusat 50 (IC x 5 Analogue,x 4 Digital)
Paul.
Paul.'s picture
Aparently (Chineese water snake) snake oil is higher in Omega 3 than Salmon.  The problem with the name came from 'snake oil salesmen' not actually including snake oil in the products they sold.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
RobinKidderminster
RobinKidderminster's picture
Cant agree more ellisdj. My room treatment was cheap but so very important. I say try a little experimentation as my previous threads suggest. Lots to gain for very little money.
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
SteveR750
SteveR750's picture
More like never got round to changing the plug that I stuck one on too! I had them placed near the dust covers on the bass drivers of my AR 18BX speakers, and on a couple of LPs near the spindle hole if I recall correctly. I couldn't hear any difference whatsoever.
__________________
Covenanter
Covenanter's picture
Online
I'm not questioning what you heard but unless the test was "double blind", ie both the subjects and those conducting the test had no idea which you were listening to, then it has no validity at all I'm afraid.  No scientist would accept the result of a single blind test in any way at all.
Having said that if what you were listening to had any mechanical component then there is the possibility of acoustic feedback and I would have to say it might make a difference.  It certainly could with something as sensitive as a turntable, in fact I'd be surprised if it didn't and I remember when the world was young being convinced that it did.  I'd be more sceptical about a CD player but can see that it's not impossible.  Valve amps, yep there's a possibility because of their microphonic nature.  Solid state equipment I would be amazed but one must keep one's mind open.
If WhatHiFi want to gain credibility for their tests they need to be double blind or people like me will just ignore them.
Chris
David@FrankHarvey
David@FrankHarvey's picture
Thompsonuxb - I think your thread title should have a question mark after it. Your first post asks a question, but the lack of question mark in the title makes it look like you're stating a fact - which is only going to attract those that revel in slagging off anything that doesn't plug into the mains Smile
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
ID.
ID.'s picture
Online
While I'm a believe that they can make a difference, one could raise the point that you were already expecting to hear differences, and this may have influenced your perceptions.
__________________
Observe the signature in its natural habitat.
ellisdj
ellisdj's picture
I don't see why double blind matters - they had no input just changed the cd and moved the CD player, all done behind us so we had no idea what was going on.  Then they took our comments related to what we thought after each song was played as many times as we wanted on system a b or c
They changed the order it was played in as well to remove any preference from the test before
There was consistency as well - I preferred one sound and chose that every time as my preference from the 3 so that clearly shows I could hear a difference in that presentation that I liked
it was hard to tell sometimes, very hard but at the same time the differences were there and consistent
Sitting there listening for differences does have an effect psychologically - with other factors as well didn't know music, never heard system before - however that removes prejudices so is better
sounded excellent as well - the seperation and space between everything was stunning never heard anything like it.  The ray Charles song there was a band playing in front if us - all spaced out going back about 4 feet behind the speakers - brilliant!
That was off a Cyrus cd6s nothing mega high end,the amp was moon i6 I think MA platinums, epic speaker cable, not sure interconnects.  They have stunning test facilities
__________________
bigboss
bigboss's picture
If you're playing music off a NAS drive via Sonos, will the surface matter?
__________________
ellisdj
ellisdj's picture
thats a very interesting question - I have a similar system - music is fed via my home network to a network card / dac analogue  output . Therefore no moving parts in the audio end point so you would assume affect less maybe
I can tell you my experiences soon when I get the hifi racks podium, however I have messed around with my speakers with the coming new sofa so that has thrown out my mccac calibration so it won't be a fair test. I will have to run mccac again as my centre will be raised considerably but I can still report back general findings.
someone else might know more??
__________________
CnoEvil
CnoEvil's picture
My Linn DS sounds noticeably better with Black Ravioli under the chassis!
__________________
