Arcam rWAVE dongle makes my internet slow..
10 replies [Last post]
Walkzinho
Walkzinho's picture
Hi all,
My rWAVE when plugged into the macbook really seems to affect the speed of my internet for some reason, it makes it crawl! I know its the rWAVE as when I unplug it and reconnect to the internet its up to normal speed, plug it back in again and it knackers it straight away  Shock
Has anyone else experienced this?
__________________
Macbook Pro/rWAVE --> Arcam rDAC wireless --> Atlas Equator Mkiii --> Naim NAC152/NAP155 XS --> NAC A5 speaker cable --> Rega RS5
chebby
chebby's picture
Online
RE: Arcam rWAVE dongle makes my internet slow..
Your wireless network will run at the speed of the slowest thing in it.
If someone had an all 802.11n network and plugged in an 802.11g device, then the whole network will run at 'g' speed.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Walkzinho
Walkzinho's picture
I thought the rWAVE was bluetooth? As far as i know its not connected to my homehub?
__________________
chebby
chebby's picture
Online
Apparently it uses something called 'KLEER' (whatever that is) so it shouldn't interract with your wireless.
But, from your description, I guess it does.
Maybe Arcam support can help.
__________________
karlmc
karlmc's picture
Kleer uses the same 2.4GHz frequency range as wireless 802.11 so first thing I would try is to change the wireless network channel on your router.
__________________
Naim nait xs , naim nd5 xs, spendor A5 , michell focus one with linn basik plus arm and ortofon samba mc , ca 640p , chord anthem , chord chorus 2 , chord epic twin , chord signature digital , chord powerchords.  Pioneer sc-lx 73 , denon dbp2012 , pioneer pdp5090, spendor c5e , mordant short surrounds, Rel T5.
Gopi
Gopi's picture
Hi Walkzinho
I have been experiencing the exact same problem. It is definitely rWave because I then remove it and it is all fine. Mine is also a Mac book. I don't know if this is a Mac specific issue Sad
Mine is one of the first rWave not sure if the latest ones have an updated software that might address this problem.
John Arcam Dawson
John Arcam Dawson's picture
I am not at work to check with the guys who really know the answer but, from memory, it is to do with where the Mac's wireless aerial is situated - i.e. very close to the USB sockets. A short USB extender cable from the USB socket to the rWave should fix this.
HTH.
John Dawson (Arcam)
Walkzinho
Walkzinho's picture
Thanks for your reply John,
that kinda negates the whole portable aspect of the rWAVE though, my usual listening environment is with laptop in my lap or at the desk doing work, I bought the rDAC to get away from cables!
__________________
shafesk
shafesk's picture
Hey Walkzinho, to me this sounds like network interference. I would try to change the channel of the router to something less common, this will increase internet speeds as well as reduce interference since there are probably tens of wifi networks in your area. Second, I would suggest you change your router to something that has a 5ghz network if you are using a laptop/pc which can connect to 5ghz networks. 5ghz is usually not a frequency used by microwaves, cordless telephones and certainly not Kleer devices if I recall correctly. I also find that the 5ghz network on my airport extreme is faster than the 2.4 ghz network. Mind you, there are drawbacks to a 5ghz network, it's range is a little less than the 2.4 ghz ones....but shouldn't be an issue if you have a medium sized house.
Regards,
Shafin
__________________
Hi-fi:
Denon DNP-720AE network streamer, Mordaunt Short Mezzo 6, Cayin A-55 T, Technics-SLQ210, Denon DP-29F turntable, 540p, Dac-magic, Marantz 5004CD and 6025 Turntable, Mac ,Pure AV interconnects, QED Revelation speaker cables, QED Performance interconnects.
Head-fi:
Akg K702, Grado SR60i, UE Triple-fi, Musical Fidelity X-cans, HRT Music Streamer 2+
Gopi
Gopi's picture
Hi John,
Thanks for the reply. I don't have any extenders with me. So, will try once I get one.
Walkzinho,
You get cable extenders that are just a few inches in length which is not bad.
John Arcam Dawson
As far as I know this issue is a Mac laptop one so it is perhaps not fair to blame the rWAVE ;)    And, as someone else just said, you can get very short extenders. It's worth a try.... let us know how you get on.
