9 posts / 0 new
Last post
Lo Fi's picture
Last seen: 3 years 3 months ago
Help selecting headphones required
I have an Audiolab 8200 cd player and Arcam FMJ A19 amplifier and require some headphones. I am thinking either Audio Technica ATH M50 or AKG 550 what do members think would be best or are there others at a similar price that are good. I want closed back type.
quadpatch's picture
Last seen: 2 years 4 months ago
RE: Help selecting headphones required
Out of those two I prefer the ATH-M50s. It has a much better and more realistic bass presentation (although perhaps a tad too strong), it's not quite as comfy but the seal and isolation was better for me. Both drive well from portable gear, but it sounds like you're not fussed about that. On the down side I find the M50s a bit muffled and the K550 a bit screachy in the highs, but they are both pretty well loved. For the budget you seem to be going for however I would recommend a couple above those two (in order of greatness, best first):
SoundMAGIC HP100
Beyerdynamic DT770 Pro
GermanMAESTRO GMP 8.35D
Anonymous's picture
I've got the 550's and they sound good but I find them uncomfortable after about
half an hour to 45mins. I'll be looking to try the Soundmagic HP100 & 200 as
they seem to have very good reviews and after using the E10's think they could be
vgood.
davidf's picture
Last seen: 2 days 10 hours ago
Depending on the sort of sound you're after, there's the Yamaha Pro500, KEF M500, Onkyo ESHF300, Sennheiser Momentum, and a few new DENON models coming too that will be worth taking a look at.
the little audio company, jewellery quarter, brum
audioquest / audio technica / bluesound / chord co / cornered audio / golden ear / harman / innuos / jbl / kef / moon / ophidian / primare / revel / svs
quadpatch's picture
The first ones you mention stand out to me as hifi manufacturers that don't know much about headphones, coming into the market because of the opportunity created (for better or worse) by Beats. I'm not saying they're bad, but I hope they've gotten someone else to make them. Also many of your suggestions seem a little expensive (£200-300), given the one's initially mentioned (£120-150).
dalethorn's picture
Last seen: 12 hours 26 min ago
I hope KEF gets the sound of their new headphone up to mid-fi standard at least. Another Martin-Logan Mikros 90 we don't need. But I would definitely recommend the production version of the Beyer DT770LE 32 ohm. And I'd say the Soundmagic HP200 gets closer to the DT770 sound than the HP100, but the HP200 is on the HP100 side of that comparison, not the far side beyond the DT770, if that makes sense.
Focal Elear, Beyer DT1770/T70p, Grado PS1000e, B&O H6, DragonFly1.2/DragonFly Black/Oppo HA2 DAC/amps, Lehmann Traveler amp.
Pete68's picture
Last seen: 3 years 7 months ago
I have heard excellent things about the Yamaha HPH-MT220 headphones. They are priced at about £130. Definately worth an audition.
dalethorn's picture
"Copper clad aluminum wire voice coils". Ummm, that would not be my preference, unless there's an important design goal there besides cutting costs. I searched for reviews for the MT220, and could not find even one review, although they were announced nearly a year ago.
Lo Fi's picture
SoundMAGIC HP100
Hi quadpatch from reading some of your posts I can see you have a great knowledge of headphones.
Can you tell me the pros and cons of the following headphones bearing in mind I will be using them only through the Arcam amp.
ATH M50
HP 100
DT770 Pro and by the way which impedance would be best
Thanks for your help
Log in to post comments
