How can I find out my network password?
53 replies [Last post]
JoelSim
JoelSim's picture
Just had the hard drive replaced on my MacBook, no it didn't need it, and the problem with the fan which I took the stupid thing into John Lewis for is still a problem. What is it with nerds that they don't listen to anything you tell them!
Anyway, the upshot is I have lost everything off my hard drive, so I need to reload various things like Office, Airtunes, Spotify etc etc. But I don't have the WEP password to get onto my wireless network (currently using the missus' computer).
Can anyone help? For info I didn't set the network up in the first place so I have no idea what the password is. Grrrrr, those meddling kids!
To top it all off my computer still needs the problem looking at and I am left needing to reload loads of rubbish too. Grrr again!
Funnily enough the warranty report stated that they had tested it thoroughly after being 'fixed' including running the DVD drive for 2 hours. Grrrr again as it doesn't have a DVD drive.
Upon complaining to Customer Services at least Emma was very understanding about my plight and they have agreed to pick it up next Wednesday to fix it again, and loan me another computer for the duration and have given me £20 for goodwill.
JD if you're reading this, I've gone through the process you mentioned last time to retrieve my password on preferences using the pencil icon but even when you click 'Show password' it just comes up with asterisks.
Help...
__________________
Unison Research CDE, Leema Tucana 2, Kudos C2 and some cables.
maxflinn_banned
maxflinn_banned's picture
Re: How can I find out my network password?
i think that if you connect directly to you're router using an ethernet cable, you can go into the routers settings and recover the password...
__________________
laptop...airport...marantz pm7001...dynaudio dm 2/7's...
JoelSim
JoelSim's picture
maxflinn:
I don't have an ethernet cable though.
__________________
JoelSim
JoelSim's picture
Is there a way I can retrieve it from my iPhone settings perhaps?
__________________
John Duncan
John Duncan's picture
I'm nowhere near my wireless at the moment so can't remember whether you can 'show password'. You could always have a look and see...
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
maxflinn_banned
JoelSim:
maxflinn:
is there not one going from you're phone line output to you're router? if so, unplug it and connect you're mac to the router, you dont need to be online to get you're password, but i think you need to type in said routers code into you're pc's adress bar, for example, a belkin routers adress is 192.168.2.1,i think, tell us what make router you have and we should be able to find its code?
__________________
scene
scene's picture
No, not easily. Best solution is max's, which is to connect with an Ethernet cable. Hang on, if you're using your wife's computer to access the Internet, and you're going via the wifi router, you should be able to connect to the router's admin page via your web browser. Usually on 192.168.1.1. From there, you should be able to find the weep password.
__________________
Hi Fi: Arcam A85, DV88 (CD only), Project Debut II, AE Compact-1. AV: Arcam AVR250, DV79, Sony BDP-S760, Monitor Audio Silver 8i, RS-LCR, RXFX, Sonos ZP90, Pioneer KRP500A. 2nd AV: Pioneer SX-SWR2, Dell Zino HD, KEF KHT2005.2 eggs, Sonos ZP90. That Cable HDMI, Chord Crimsons and Sonos ZPS5s everywhere & a spare Yamaha RXV-667!
JoelSim
JoelSim's picture
scene:
How do I do that?
__________________
JoelSim
JoelSim's picture
maxflinn:
JoelSim:
maxflinn:
I'm a bit worried about unplugging the router cables, all sorts could happen then
__________________
maxflinn_banned
JoelSim:
scene:
How do I do that?
what make is you're router?
__________________
JoelSim
JoelSim's picture
It's a Speedtouch 585 v6
__________________
maxflinn_banned
192.168.1.254
__________________
scene
scene's picture
JoelSim:
scene:
How do I do that?
If your wife's pc is connected to the network, load your internet browser and type http://192.168.1.1 in the location (for a netgear router) or http://192.168.2.1 for a belkin. This should popup your router's admin page. Username default is admin, password admin (if you haven't changed it).
EDIT go win max's suggestion for the address.
__________________
JoelSim
JoelSim's picture
What do I do with that number Max?
__________________
JoelSim
JoelSim's picture
OK I have a screen up now, what next?
__________________
scene
scene's picture
Type it in your network browser's address bar (on your oh's pc)
__________________
