22 posts / 0 new
Last post
L00k_C's picture
Last seen: 2 years 10 months ago
KEF LS50 - Stand, subwoofer, amp
Dear All
I have auditioned the LS50 yesterday and they sound great. However, I found that I wanted some more bass in them. The guy in the shop suggested the Rell T-7 and T-9 sub to be connected in parallel. Any ideas?
Furthremore I would also like to know what speaker stands are most appropriate. I am currently looking at;
Custom Design FS104 Signature, Partington Super Dreadnought and Partington Ansa 60.
Latsly which hifi amps would you suggest for them?
Any input is welcome.
The_Lhc's picture
Last seen: 2 months 2 days ago
RE: KEF LS50 - Stand, subwoofer, amp
What both of them? Seems a little excessive...
CnoEvil's picture
Last seen: 6 days 20 hours ago
Welcome to the forum.
Can you give details of your source, and the budget you have allocated for amp and Sub.
Also, the size of your room and the type of music you like to listen to, would also be helpful.
"We should no more let numbers define audio quality than we should let chemical analysis be the arbiter of fine wines."  Nelson Pass
ABM78's picture
Last seen: 11 months 2 weeks ago
Have not heard too many subs and not sure of your budget but the PV1d sunds just right most of the time, texture, definition, speed, but not thunderous.
TheHomeCinemaCentre's picture
Wtith the price of the sub, stands and speakers had you considered the R500's? I think they have 20% off right now so you may even be able to look at R700s
CnoEvil's picture
Now that is probably the most sensible suggestion.
philipjohnwright's picture
Last seen: 2 weeks 23 hours ago
With 20% off you could probably stretch to the R900's given the cost of the LS50's, stands, and a Rel T-9! The R900's would be neater in terms of box count and wires, but you may not have the room for a big floorstander.
If the latter have a look at BK Electronics' subs (www.bkelec.com) as well as the REL's. BK used to make the original REL's and are considerably cheaper than most equivalents as they only sell direct (which does mean you can't audition them). They get very good reviews though - see the website.The top of the range one at £550 is quoted at 15Hz in room at -3db; not sure I quite believe that but it's pretty beefy whatever! If I was looking for a new sub they'd be my first port of call.
Whether REL or BK, do consider how you will connect it to your amp; there can be issues with grounding them if using the high level connection into a dual mono amp. There are ways around it (I'm using an old REL into my dual mono Ayre without a problem, but it did take me a while to work it out), but do be aware as you can 'fry' things if you get it wrong.
davidf's picture
Online
Last seen: 4 hours 48 min ago
I don't think you'd need to look any further than the R500's as their bass is surprisingly deep for their size. Having said that, I do prefer the treble and midrange from the LS50, which is much more Reference quality than R Series quality.
For a sub that is going to be good enough for music and for the LS50's, you'll need to be looking at the KK Sound DXD808, which are designed for speed and accuracy rather than all out depth and SPL (although they're really rather good in those respects for their size as well). I use a DXD12012 with mine and they both blend seamlessly, and compliment each other perfectly as they both have a similar design ethos behind them.
owner at thelittleaudio.company
high quality audio solutions for real world music lovers
michael hoy's picture
Last seen: 11 months 1 week ago
I thought the 20% discount was only on thr Reference and Q series.
AV- Panasonic VT30¦Pioneer LX85¦MA Apex Speakers¦Antimode 8033S¦OPPO 95 BDP
Hi-Fi- Spendor A3¦Cyrus 8 XPD QX¦Quad 909 power amp
Music stored on Server running Windows Home Server.
CnoEvil's picture
I think you might be right - T, Q and Ref series is now what I've read.
csq2's picture
Last seen: 2 years 8 months ago
LS50 is much more transparent sounding than the R500s. The top end on the R500 seems veiled to me and the hefty bass is bothersome- not as tight as the LS50. Also, the R500s require a VERY powerful amp. IMO, the LS50 looks much better than the R500s which is too flashy for my tastes.
davidf's picture
Online
Correct.
The Little Audio Company
audioquest / audio technica / bluesound / chord co / cornered audio / golden ear / harman / innuos / jbl / kef / moon / ophidian / primare / revel / svs
L00k_C's picture
Dear All
Thank you very much for your answers.
Just to put you into the picture:
1. The room is about 7x5 meters.
2. I listem mostly to rock music and also to all other music (apart from JAZZ ... sorry :grin: )
3. The suggestion was to use EITHER 1(one) T7 or T9 using the Neutrik Speakon solution (although reading further some say the use of 2(two) subs has a better result)
4. for amp budget I am in the region of upto 2000 euros (sorry just starting this hobby). I have an offer for Creek Evolution 5350 for about 1000 euros? :shifty: Should I also consider a VALVE amp solution?
5. I have heard also the R700 which are also nice (more bass), however, forgive me for saying that, but all the jizz about the LS50 (and ofcourse the quality of sound), is what drives me to buy the latter that any of the R series :shhh:
6. One more question: as I would like to expand further into Home Cinema, is using a 3rd LS50 speaker as CENTER speaker a CRAZY idea. (should i stick to a proper center speaker i.e. R200C,R600c).
Guys again THANK you VERY MUCH for your input and time.
CnoEvil's picture
Here are my thoughts on the questions you have posed:
- You have a big room to fill (even more so if it has a high ceiling), so either floorstanders or a sub may prove necessary.
- With "Rock" being your music of choice, Valves may not be the way to go.......but it's worth finding out.
-  Others have rightly pointed out, that if you take the cost of one or two decent subs, plus the cost of stands, you could be looking at really nice Floorstanders.
- Along with Creek, look at Musical Fidelity M3i, Electrocompaniet ECI-3 and Sugden A21.
- Do not buy speakers because of the "all the jizz", unless you feel it's fully justified for your taste. If you like the R500/700/900 as much, I suspect they will suit your room better (given its size).
- I think you can use a LS50 for a centre, but David (F. Harvey) can confirm.
IMO. Don't buy the speakers until you have decided on the amp and heard them together....as you should see them as a "matched pairing".
L00k_C's picture
Thanks CnoEVIL, wise words
However, If Iwas to go for floorstanders R500 (something I think I should) then Monitor Audio RX6, B&W CM9, DALI IKON 6 MK2  and Focal 826VW come into play :wall:
Any suggestions or additions? :read:
Al ears's picture
Last seen: 5 days 2 hours ago
I strongly concur with CnoEvil, if you are buying the L50's for their looks but feel they need a sub (the TZero should suffice as a pair), then you are indeed looking at the wrong reason to buy them. For the size of your room, and if you are looking to go 'home cinema' in the future then aim to audition floorstanders when you have your source and amp sorted.
Agree with Musical Fidelity as a good starter but do not stop there (Primare, Electrocompaniet etc, etc.)
If you are going for a centre speaker stick with one that is specifically designed to be just that. No point in spending all that extra on a speaker that you will hardly be using it's full frequency spectrum. Smile
Valve amp will not be the way to go if yor main interest is rock and aim to go for home cinema at a later date!
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
Pages
Log in to post comments
