Sound Fowndations introduces the Clearaudio Master Innovation turntable
Latest model is derived from Clearaudio's flagship Statement turntable, with which it shares cutting-edge tech
Its looks alone should get you salivating over this new turntable from Clearaudio, the £14,500 Master Innovation. It's a step up from the five-star, £12,900 Innovation model we've already reviewed.
It's based on some of the technology found in the firm's flagship Statement model, but at a fifth of the cost. Not cheap, then, but somewhat more affordable. Clearaudio says its aim is "to produce a performance from vinyl records that even the original recording artists could only dream of". That's quite a claim.
The Master Innovation has a floating main platter assembly that revolves without any physical contact with the drive source. It consists of a two-piece main platter, an upper magnetic drive platter and a lower two-piece magnetic drive platter.
A narrow gap separates the upper and lower magnetic drive platters so they do not touch each other. Instead, a ring of powerful magnets embedded in each transfers drive from one to the other and the entire main platter assembly floats on, and is driven by, the magnetic field.
MORE: Read all our Clearaudio turntable reviews
Other technical highlights include a ceramic magnetic bearing, and an optical speed control for optimum speed stability and control. The lower magnetic drive platter is a two-piece design, the lowest part being a 1.5cm-thick stainless steel platter on the underside of which is a stroboscope ring etched with 1500 tiny bars.
The stroboscope ring is read by an infrared sensor thousands of times per second and the information is fed back to the motor, which is then adjusted as necessary.
The latest hi-fi, home cinema and tech news, reviews, buying advice and deals, direct to your inbox.
Supporting all this is a four-level chassis which is constructed from a complex sandwich of Panzerholz – a wood-based, bullet-proof armour plating material – and aluminium.
You can buy the Clearaudio Master Innovation through UK distributor Sound Fowndations in two versions: with a wood finish for £14,500 or the black finish for £15,400. Owners of the existing Innovation model can upgrade to the new Master Innvation if they want.
MORE: Read all our turntable reviews
By Andy Clough
Andy is Global Brand Director of What Hi-Fi? and has been a technology journalist for 30 years. During that time he has covered everything from VHS and Betamax, MiniDisc and DCC to CDi, Laserdisc and 3D TV, and any number of other formats that have come and gone. He loves nothing better than a good old format war. Andy edited several hi-fi and home cinema magazines before relaunching whathifi.com in 2008 and helping turn it into the global success it is today. When not listening to music or watching TV, he spends far too much of his time reading about cars he can't afford to buy.
