FM's poor quality
14 replies [Last post]
Hughes123
Hughes123's picture
With the arrival of my new headphones with a very extended frequency range, I can now truly hear the quality of my sources. My FM tuner, the Rotel RT-02 though, is a bit poor. To start with, there is distortion on the transients of music even though the signal strength is at maximum, the bass is very flabby and the treble seems to have no extention what so ever and occupies just one "tish" sound. Is this the quality of FM, or is it my tuner?
matthewpiano
matthewpiano's picture
Re: FM's poor quality
Its your tuner. Get a Denon.
__________________
Rega RP3/Elys 2, Roksan K2 CDS, Squeezebox Touch, Denon PMA720AE, Q Acoustics 2020i, Sennhesier HD595, Beyer-Dynamic DT770PRO, Chord Crimson/Chord Rumour 2
Hughes123
Hughes123's picture
matthewpiano:
But my Rotel is much more expensive than the Denons - surely it must be better? On Radio 3 and 4 it's very good, but on the rest it's poor - is this really right?
John Duncan
John Duncan's picture
Hughes123:
matthewpiano:
My Primare is much more expensive than my Airport Express.
Have you got a roof aerial?
__________________
CA StreamMagic 6  |  CA 751BD  |  CA 651A  |  PMC DB1i
Moderator. mail: john.duncan.whf at the mail of g dot com
Andrew Everard
Andrew Everard's picture
Could just be that the other stations you're listening to use fairly aggressive compression.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
Hughes123
Hughes123's picture
JohnDuncan:
Hughes123:
matthewpiano:
Ok, I admit I don't have a roof aerial, but I have a huge roof aerial installed in the loft and mounted on the wall high up in there too.
Andrew - I guess it may be the compression, but it's quite annoying whatever it is!
a.g.
a.g.'s picture
If Radio 2 sounds bad then something is wrong somewhere along the line.
Andrew Everard
If Radio 3 does, even more so.
__________________
JoelSim
JoelSim's picture
My reception is so poor my Arc goes onto auto mute sporadically
but then I do live in a rural outpost called London. My mobile doesn't get reception downstairs either. Grrrr
ÿ
__________________
Unison Research CDE, Leema Tucana 2, Kudos C2 and some cables.
Gerrardasnails
Gerrardasnails's picture
matthewpiano:
Use your Sky box if you have one.
__________________
Screen - Samsung UE46D8000.  Sources - Dell Zino HD 410; Sky HD; Sony BDP S550; Wyred 4 Sound DAC1.  Amps - Yamaha RX-A3010; SimAudio Moon I-3 RS.  Speakers - Vienna Acoustics Mozart Grand; Vienna Acoustics Waltz Grand centre; Proficient Audio W690 rears; Monitor Audio RSW12.  Cables - Van Damme Blue 4mm speaker cable; Townsend DCT300 and Atlas Voyager interconnects; Van den Hul Optocoupler.
Hughes123
Hughes123's picture
Gerrardasnails:
matthewpiano:
Don't have Sky sadly, but I do have quite a few decent Freeview tuners around...
fatboyslimfast
fatboyslimfast's picture
there you go then...job done!
__________________
Sources: Technics SL1210Mk2 with Denon DL110/AT-95E, Mac Mini, Virgin V+.
Amplification: Cyrus 2.
Speakers: Mordaunt Short MS20i Pearls with Fisual Super Pearl 2.5mm cable.
Other kit: More than I should have. My loft is creaking.
matthewpiano
Well I'm listening to FM on my TU1800DAB and it sounds fantastic, even without a roof aerial. Its pulling in a really strong signal and sounds eons better than DAB.
Just because the Rotel is more expensive doesn't mean its better. IMO Denon have made the best reasonably priced tuners since the original TU260L.
FM is still the best radio.
__________________
the record spot
the record spot's picture
JoelSim:
My reception's so poor I do my own news bulletin.
(Coat - get - leave - taxi!)
__________________
Onkyo TX-8050 / Tannoy Revolution DC4 / Marantz SA7001-KI / Apple TV 3 / Sony PS3 320Gb / Denon DVD-3930
the record spot
Hughes123:
As someone else, somewhere else said recently, not so, else we'd all be buying Bose.
__________________
