Fibre optic just installed
3 replies [Last post]
camcroft
camcroft's picture
Hi.I have just had fibre optic installed .I am having a problem getting my Sky wireless connector to link up to my new router which is a Brightbox from EE.I am trying to connect it so that I can have on demand on sky.Everything works perfectly Ipad picks up all over the house its just the Sky wireless connector.Can anyone advise me what to do.Thanks help, I`m sinking
__________________
Marantz SR5023 - Marantz CD5003 - Project Debut Carbon Turntable Black gloss with acrylic platter & Rega Mini phono stage with Atlas Element Integra cables;Monitor Audio RX1 Black gloss Speakers.-Chord Carnival speaker cables.Atacama Nexus 7 speaker stands
Andrew Everard
Andrew Everard's picture
Online
RE: Fibre optic just installed
Sky suggests two things to try:
First...
Go to your My Sky and check that the service is showing as active
If it's showing as active, follow these steps:-
1. Select services on your Sky remote control
2. Go to settings
3. Select network (this is in the middle of the page on your box on your television)
4. Press the red button on your remote control, this will re-set your wireless connection between your box and the wireless connector
5. Put in your router password again
Once the above steps have been completed try getting onto your On Demand service.
Or it should be possible to connect the BrightBox and the Sky wireless box using the WPS facility, if this is enabled on the BrightBox.
To enable it, log-in to the router at http://192.168.1.1 and sign in, then
  1. Click on the basic set-up tab.
  2. Select wireless settings and then wi-fi protected setup.
  3. Select the option 'Enable' and then click on apply changes:
The router will then make those changes, and then you can just press and hold the WPS button on the router (it's round the back, next to the power input) for five seconds, until the WPS light starts flashing
While it's flashing, press the WPS button on the Sky wireless box, and the two will should connect.
Second...
There are instances where the On Demand service does not work effectively with the default setup on some routers provided by alternate Broadband providers (please note this issue does not affect Sky Broadband Routers / Sky HUB).
In order to resolve this issue you will be required to ammend the default setup of your Broadband router. For further information in relation to the default setup of your router or the amendment of settings please refer to the user manual provided with your equipment.
1. Access the setup page for your router. This can be accessed by pointing your browser at 192.168.0.1 or the IP address listed in your routers manual.
(Again, this is http://192.168.1.1 for the Brightbox)
2. Select the ADSL Settings Section.
3. Change Multiplexing Method to "LLC-BASED"
4. Select apply.
Your On Demand connection should now work effectively. You should not require to restart the router.
It then says
Should you continue to experience issues after following the steps above, please contact your Internet Service Provider for assistance.
__________________
Consulting Editor, What Hi-Fi? Sound and Vision/whathifi.com  Audio Editor, Gramophone
camcroft
camcroft's picture
Hi.Andrew.I cannot thank you enough.I got in touch with EE and they said all the settings were correct and then I scrolled down the page of what you had wrote and followed the wps bit changed the settings and bobs your uncle.Cheers mate beauty, eh
__________________
Andrew Everard
Online
No probs, happy to help – it's what we're here for.
And FWIW I do have an uncle called Bob – well, he's actually called George, but then so was his father, so my grandmother always called him Bob so it was clear which of the two of them she was shouting at Wink
__________________
