Party speakers
27 replies [Last post]
Keepit
Keepit's picture
Hey all, just wondering if I can use your expert opinion.
I'm currently buying myself a new set of speakers for uni next year, my current system is a NAD 3130 from 1985 running two Monitor Audio R252.
 I'm looking to replace my current speakers with some new party speakers able to withstand loud sounds and large amounts of bass, but also keep a good quality. The best I've found so far are some Pioneer CS-7070 with a 10" driver and a good price tag of £200  http://www.pioneerprodj.eu/uk/products/42/99/161/CS-7070/specs.html
 How well will they run on my amplifier? Are they good speakers? I'm not looking for perfect monitor studio perfection, but some quality would be nice.
ear
ear's picture
Re: Party speakers
only know the cs-3070. and I like them very much.cheap and very good 3 way speakers.detailed sound, and good bass.
__________________
Yamaha AX-397 + Yamaha NS-333;
HK 3390 + Tangent Millennium 200;
Cambridge Audio Sr10 +Cambridge audio  S30
Keepit
Keepit's picture
Re: Party speakers
Wow, thanks for the quick reply. And your opinion.
 Any worry with my Amp? it should be fine for ohm's just the watts are quite a lot higher on the speakers, so the amp won't be able to drive them to a high volume?
ear
ear's picture
Re: Party speakers
the 3070 are very easy to drive.I guess these would suffice to what you want.
__________________
MattSPL
MattSPL's picture
Re: Party speakers
They're not big huge speakers, but i used to have a pair of mission 731i's.
Ran them off a 20watt Nad 310 amp. Plenty of volume.
Sold them to my mate who still uses them with his decks powered by a Marantz 60watt amp. They have serviced many a party for 15 years now and still work perfectly even with the dust caps of the bass drivers pushed in.
He has a monitor audio active sub for extra bass. Works very well as you can control the amount of bass you want for normal,use or flat out party levels.
__________________
Arcam Cd33 > Matrix Quattro Dac > Digidesign RM2's on Partington Broadsides > Velodyne DD12 > And some mains cables that make it sound better Smile
MattSPL
MattSPL's picture
Re: Party speakers
You'll get some mission 753's on ebay too. Big tall floorstanders that will do a party nicely
Some cheap mission 734i's on ebay at the moment
__________________
cjackson
cjackson's picture
Re: Party speakers
Possibly try TDL they make good speakers
David@FrankHarvey
David@FrankHarvey's picture
Re: Party speakers
I find 'party speakers' don't make the best hi-fi speakers. Basically what you're after is a pair £200 speakers with the qualities of KEF Reference, which we know isn't going to happen. With that in mind, try the Wharfedale Xarus 5000 - 3x 8" bass drivers (or 1x 8" mid/2x 8" bass - not sure!). Big loud speakers for not a lot of money (around £150).
Although don't forget that whichever speakers you choose will be limited by your amplifier's output.
__________________
David @Frank Harvey Hi-Fi, Coventry
Mitsubishi HC7000 / Oppo BDP103 / Audiolab 8200AP / Rotel RMB1575 / kick ass speaker system
Keepit
Keepit's picture
Re: Party speakers
Thanks everyone for your response.
 FrankHarvey, those Wharfedale's sure do look good, I wasn't looking for floorstanders, or that size, but for that price! I'd have trouble beating it.
 My only worry is, my amps 8ohms, and they're 6ohms, would that cause any issues?
Going to be interested explaining what I'm using those speakers for to my landlord. ;)
chebby
chebby's picture
Re: Party speakers
Find the cheapest, rattiest, old pile of ____ amp & speakers (that still work) on ebay and use them for the party.
Take them to the local dump the next day. Most dumps have a place where someone will sell things like old electronics, furniture etc to students for a fiver.
In fact go to the local dump first (before ebay) and look for something suitable.
People at parties don't give a local dump about sound quality so long as it is loud and they can put their drinks and ashtrays on the speakers. People at parties only want to drink and pull. They don't need hifi for that.
Just use one speaker (no-one will know) and keep the second speaker as backup in case some twonk blows the first one up/falls on it/is sick on it/sets fire to it accidently.
Put your good hifi in storage for the night/weekend because some-one will try and steal it.
(I wrote the above on the basis that you mentioned Uni in your post. I have seen at first hand the aftermath of student parties and it sometimes involves all three emergency services!)
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
Keepit
Keepit's picture
Re: Party speakers
I got my NAD and MA's for a cheap party setup secondhand, this is the end of my second year, and after a good 20 months of bullying the MA's are abit warn out. Which is why something with more grunt and which can take a little more of a beating is good. But I also need something which I can do my digital audio editing on for my digital filmography as well. I don't want monitor quality though.
I've never come across anyone attempting to steal anything, I probably don't have parties as crazy for that. Quite often its just doped out sofa sessions listening to dubstep and some dnb.
 Cheers for your input though
David@FrankHarvey
Re: Party speakers
Keepit:
6ohms will be fine, you'd only need to worry if they were 4ohms.
They're also 92dB sensitivity, which means they're louder than most speakers for any given volume Yes
__________________
AEJim
AEJim's picture
Re: Party speakers
Here - Smile
__________________
Brand Manager, Acoustic Energy Ltd.
brittondave
brittondave's picture
Re: Party speakers
AEJim:
Here
- Smile
YES YES YES..........buy these....
brings back so many memorys of uni parties....
these can withstand almost anything.........
Brutal!!!!!
Keepit
Keepit's picture
Re: Party speakers
I would snap them up straight away, but its only for 1 speaker
brittondave
Re: Party speakers
sheesh kebabs...........well noticed ....very sneeky.
well you could try and do a deal over the phone for  a pair or.......
these
£10
http://www.avbristol.co.uk/product_info.php?manufacturers_id=9&products_id=243
