7 posts / 0 new
Last post
Ace
Ace's picture
Last seen: 2 years 5 months ago
Over-ear Headphones: max 100€
Hi I want to buy a pair of headphones and I'm looking for suggestions. Here are my criteria:
Budget: max 100€, can go up to 150€ if it's really worth it
Source: Laptop, PC, Iphone 4S, Playstation 4
Requirements for isolation: Decent isolation prefferred, but it's not that important.
Preferred type of headphone: Over-ear
Preferred tonal balance: Just balanced good quality, but I do like bass.
Preferred Music: Everything, but not Rock/metal.
I really need a multimedia headphone. Like I'm going to use it for watching movies, listening music and playing games. So compatibility with devices is really important. (PC, PS4, Iphone) Comfort is also really important for me. I have considered these headphones so far: Kingston Hyperx Cloud, Beyerdynamic DT 990 pro 250 ohm. Thoughts about these headphones would be appreciated. Of course I'm open for any new suggestions.
dalethorn's picture
Last seen: 1 week 2 hours ago
hybridauth_twitter_452448244
On ear or around ear?
Focal Elear, Beyer DT1770/T70p, Grado PS1000e, B&O H6, DragonFly1.2/DragonFly Black/Oppo HA2 DAC/amps, Lehmann Traveler amp.
Ace
Ace's picture
Ace
Around ear. I was considering hyperx cloud, because I would have enough money left over to buy a dss2 surround sound processor, which is neat to have for gaming.
So that's why I prefer that the price tag is under 100.
Sebastian Pierre's picture
As I recall, if you want a
As I recall, if you want a headset for the PS4 you need to check if it works. The best place so far to look is this google doc. https://docs.google.com/spreadsheet/ccc?key=0AlZqOp62pcY_dHh5dm5fS3VVaGs5VnNKN0ZFaGhUaHc&usp=sharing#gid=0
Seb
dalethorn's picture
Seems to me you'd need to
Seems to me you'd need to know 2 things for compatibility: The amount of power/signal each device puts out at a given impedance, and what the plug-in jack requirements are. You should be able to find adapter plugs/jacks to meet your needs, so your remaining worry is whether the headphone will play loud enough on all devices. If there are other issues, I don't know.
JoelSim's picture
Last seen: 1 year 2 months ago
Audio-Technica ATH-M50 are
Audio-Technica ATH-M50 are great value at the moment and fit your criteria well.
Director
www.musictoyourears.co.uk
System: Unison Research Unico CDE with upgraded DAC, Leema Tucana 2, Kudos Cardea C2, AIAIAI TMA-1 Studio Young Guru, Beyerdynamic MMX102iE.
JoelSim's picture
Or the very light weight, magnesium ATH-OR7.
Director
Log in to post comments
