Yamaha V673 PCM issues!
2 replies [Last post]
Jbtailoring
Jbtailoring's picture
Hi, I have been trying to remove the PCM audio signal and have had no luck. I can only get a very flat sound and cannot change this signal. Do we need the coaxil cable for the 7.1 from the satellite box or can we run this with the HDMI cable?
How do we change the audio signal to 7.1? Any help would be greatly appreciated. Very frustrated.
help, I`m sinking
Andy Clough
Andy Clough's picture
RE: Yamaha V673 PCM issues!
Are you running a Sky box? If so, yes, you'll need to run a coaxial cable from the Sky box to the Yamaha receiver to get surround sound. And those programmes broadcast with surround sound will generally be 5.1, not 7.1.
__________________
Andy Clough is Brand Editor of What Hi-Fi? Sound and Vision and whathifi.com
RobinKidderminster
RobinKidderminster's picture
Think we need more info on yr setup. U need optical or digital coax from a sky box for DD sound. Most other boxes send thru hdmi. PCM suggests u are sending a Dolby PL signal to yr Yam. The Yam should indicate its sending signal to 7.1 speakers if it receives a PCM signal by processing.
Beat me to it Andy. DD signal will be 5.1 but PL2 will process to 7.1
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
