USB FLAC through Yamaha 2065
5 replies [Last post]
RobinKidderminster
RobinKidderminster's picture
Online
I have experimented with a few flac files from a usb memeory stick plugged straight into my 2065 and I recon the sq beats that thru cd/sony bdp. Is this to be expected or is it the old plecebo voodoo gremlins pokin' me old eardrums?
Cheera
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
RobinKidderminster
Online
RE: USB FLAC through Yamaha 2065
I should add that the flac file was a burn from the same cd via laptop. I recon too that the usb direct sounda better than the same flac played thru my seagate theatre.
Hopefully someone can comment.
__________________
RobinKidderminster
Online
No replies? Oh FLAC!  boohoo
__________________
Trefor Patten
Trefor Patten's picture
If you think it sounds better, it does sound better - enjoy Cool
The_Lhc
The_Lhc's picture
Agreed, not sure what anybody can be expected to say, you have a lossless rip, the shortest possible signal path, you're (presumably) using the same pre-amp and amp stages if you were listening to the BDP through the Yamaha, it would be a surprise if it didn't sound at least as good if not better.
__________________
No signature worth mentioning...
RobinKidderminster
Online
Thank you kind Sirs. Fair comment. I guess, undeestanding that bdp were poorer for cd play I figured the cd reading was less accurate than pc rip added to a shorter path. I will let my old ears guide me but I questioned the reason why.
Thanks again and have a goo$ day.
RobinK
PS Good Horizon series currently featuring the LHC.
__________________
