Phono Stage advice needed
Tue, Jan 26 2010, 10:21PM
I have just replaced my amp with a Cyrus Pre vs2 / X Power combo. Because of this I am now in the situtation of needing a phono stage for the first time as my previous amps have all had an internal one. My turntable is a Roksan Radius 5 with an modified RB300 arm with a Technoweight upgrade and Incognito Silver rewire. My current cartridge is a Goldring 1042 (mm). As said previously, the Phono stage will be connected to Pre vs2 / X Power and ATC SCM 11's. What sort of level should I be looking towards, to get the most from turntable without going to silly prices?
Jamie
Graham Slee Gram Amp 2 Communicator, Creek OBH 15 / 18. At around 150 -200 mark....
Musical Fidelity VLPS at about 80 squids.
The sky is the limit on how much you want to spend.
