Spotify data gobbling problem
11 replies [Last post]
HDNumpty
HDNumpty's picture
Hi all
I was very pleased when Spotify enabled higher-quality 320kbps streaming on mobiles.  However, I've encountered another problem and a very expensive one at that...
Having now become addicted to Spotify, I am listening on the way to work, at lunchtime, in the playcentre with my kids, in the evening (my TalkTalk router is a bit poor and 'comes and goes' at the top of my 3-storey house) and I'm getting through 1GB of data in less than a week.
I'm with O2 who don't provide unlimited data over 3G - they charge £10 per month per 1GB of data, which is a bit stingy.
At 320kbps I've calculated that a months data only gives me 6hrs 40mins of Spotify time EVERY MONTH - which is rubbish!
I'm noww cancelling Spotify Premium AND my top-whack data contract just to save some money as I've concluded that ordering CDs from Amazon is a much cheaper way to get music - and better quality.
Anyone else run into this data problem, and which mobile provider are you with if so?
__________________
Music: Stream Magic 6, CA 740c, Onkyo NDS-1, CA 840a, B&W CM1
Movies: Pana 37" plasma, Sony BD, Humax Foxsat HDR, Sony DA-2400ES, MS surrounds, REL Sub
Mobile: iPad 4 64GB, iPhone 4, iPod Classic 120gb, Sony XBA3/Audio Technica ES7, Apple Lossless, iPlayer, Spotify
Paul.
Paul.'s picture
RE: Spotify data gobbling problem
I burned through two gigs in two weeks when iTunes Match first started. Luckily I have the original O2 iPhone simplicity tariff and I have 'real' unlimited internet.  I would seriously consider looking at three if you are not tied in for too long.
__________________
Paul's BR/805 system thread
(where the photos live) Paul's Flickr page
daveh75
daveh75's picture
Use offline mode.
__________________
JVC DLA-X30•Grandview Cyber Series (92")•LG 50PX990•Oppo BDP-93•Humax Foxsat HDR•Humax HDR-Fox T2•Vu+ Solo²•WD TV Live•Onkyo TX-NR818•Mackie HR824 MK2•BK Monoliith DF
Sonos Connect•Studiospares Seiwin 5A
John Duncan
John Duncan's picture
+1 In your playlists on the phone, mark them as 'available offline' when you're at home and connected to your wireless network, and then turn 'offline mode' on. The songs will then be loaded on your phone and you won't use data at all. You can store up to 3,333 songs on your phone, storage space permitting. Course, they always seem to unsync every time they upgrade the app...
__________________
Cambridge Audio StreamMagic 6  |  751BD  |  651A  |  PMC DB1i | A secret shiny box | Sonos Play:3
Moderator. mail: john.duncan.whf at the mail of g dot com
HDNumpty
HDNumpty's picture
Paul - that's really frustrating as I used to be a Simplicity customer but changed to a new tariff when I bought an iPhone4
Dave - yes that would work but it means I can't access music 'as and when' - I have to download all my playlists first 'inside' Spotify - you can't sync at 320kbps, the app squashes it to 160kbps which really spoils the audio quality.  I have NEVER listened to music at anything less than about 192kbps and even then, out of necessity due to a 20GB player.
John & Dave - thanks for the responses, the main point of the Spotify upgrade is the musch better 320kbps audio quality, which isn't available (yet at least) 'offline'.  I also have some lossless tunes (about 160 at present) on my 8GB iPhone so space is also a problem.
__________________
John Duncan
Yes you can. The latest version of the mobile app has 320k 'extreme' quality mode.
And you can still go online and listen to stuff that's not synced if 3,333 tracks isn't enough for you (and sync them to offline at the same time if you have 'sync over 3G' turned on)
__________________
HDNumpty
HDNumpty's picture
Yes.  But it doesn't work Angry it keeps flicking back to 'High Quality' when you're not looking
And I make it about 2,750 320k tracks due to iPhone memory-gobbling      #GEEK-OFF   Wink
__________________
John Duncan
Ooo, so it does.  Am just resyncing at extreme now...
__________________
John Duncan
Fixed in v0.4.24, to which I am updating now...
__________________
HDNumpty
HDNumpty's picture
Cheers John I will try that.
How's the new CA kit?
__________________
John Duncan
It's great.  I'll do a review eventually, but in general it's got lots of power and clarity.  Not quite as smooth as the Naim; a bit ragged in the treble perhaps, but very entertaining nonetheless.
The bluray player especially is fantastic (as you might expect for the price), and the SM6 has fantastic sound, though you could say it looks a bit dear against the new Pioneers, for example, and can't quite compete with a Squeezebox for UI or Spotify.
__________________
HDNumpty
HDNumpty's picture
Thanks JD I'll look forward to the review
Coming back to the thread topic, I'm a bit dissapointed by the 'cloud-based future' at the mo;  very expensive for the convenience and not the best quality - we are still 'compressed' as yet but I'm sure that will change in years to come.
__________________
