Rega RS5 speakers
4 replies [Last post]
shaunj_uk
shaunj_uk's picture
Does anyone on here own or have heard a pair of Rega RS5 speakers? Seen them online for a pretty good price, but unable to audition, so curious to know peoples views of them?
Shaun
calpark46
calpark46's picture
RE: Rega RS5 speakers
As you can see from my signature I have the RS5s.
I find them to have a very well balanced delivery with plenty of snap and deep, tight bass. I can really hear the musicians playing their individual parts but gelling together.
Rega boast about them being flexible enough to be placed close to a back wall and with their front port this is certainly true. However you must give the side firing driver a bit of space or else you'll get some bass colouration. BTW I find the drivers facing out give a much better soundstage.
__________________
Naim Unitilite, Kef LS50, Grado SR80i, Sonos 5.
hoopsontoast
hoopsontoast's picture
I found this to be the best way too, drivers facing outwards on the R3 and R7 was best IME. Both worked really well near rear walls.
__________________
Sony DVP-S9000ES | DIY SET / Eagle SA100 | DIY Speakers / Eclipse TD-508 / Keesonic Kolt
alchemist 1
alchemist 1's picture
      What size rooms would the rs3  & rs5  be suitable for ?
hoopsontoast
I had the R3's in a small double bedroom, and they were fine. The R7's were used in a long and thin room, around 30m square. I would guess the RS5 and RS3 would work in anything that size or smaller.
__________________
