DIY acoustic panels
17 replies [Last post]
stevebrock
stevebrock's picture
Online
I'm interested in making some acoustic panels for my lounge, a couple behind my speakers and a couple behind me on the back wall. I've looked at B&Q which supply some Rockwell on rolls  but it doesn't seem thick enough?
Also does anybody know where I can get some pattern/colour acoustic material to cover my panels which will keep the missus happy.
I did look at Camira, they have some great material but no indication if it's is acoustic material.
Any help appreciated
__________________
Synology DS212j > Rega DAC > Rega Brio R > Rega RS1
Rega RP6 / Exact
Chord Chameleon Plus / Odyssey 2
Panasonic TX-P50 GT50 > BDP110e > Yamaha RX-V 667 > Rega Vox
bob.g
bob.g's picture
RE: DIY acoustic panels
stevebrock, there's lots of threads here on this topic, with answers to all your questions and more. Suggest you do a search first and then ask if there are any points not covered or which you fon't understand.
RobinKidderminster
RobinKidderminster's picture
Yup ! I have enough threads to knit a jumper. Rockwool RW3 or RS60 I would try to google insulation in your area. I used CCF and a mountain of the stuff was £20.
Fabric
http://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=120522711165
Nice cloth and excellent service. Cheap too
__________________
Mordaunt Short Mezzo System C - 8,5,1,9.Yamaha V2065. SonyS570. Panasonic 42in., Sky HD 1TB. Garrard 86SB. PF30. Wii. WDTV Live. Harmony One. STAX300. QED cabling. Galaxy Tab 10.1
System Photos - http://s1051.photobucket.com/user/robinkidderminster/library/?sort=3&page=1
 Base trap Project -  http://www.whathifi.com/forum/home-cinema/corner-base-trap-completed-project?page=1
stevebrock
Online
Yep ok that's all I need the Rockwell type to use thanks
__________________
Rega RP6 / Exact
michael hoy
michael hoy's picture
Contact them, they are very helpful.
The sell Cara and I also know that Lucia is good for this project.
__________________
AV System -  Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
stevebrock
Online
Whys the best thickness to get? 50mm? I'm going to cover them ad mount them on the walls
__________________
Rega RP6 / Exact
RobinKidderminster
100mm for walls. 150min corners. 50mm easier to handle and cut than 100mm. More easily available too.Most use a stout frame but my build is lighter using 6mm wooden panel & bolted corner brackwts. Wire used to brace the frame corner to corner.
Dependant on room but I found corner triangles worked the most magic.
__________________
sheggs
sheggs's picture
Both Cara and Lucia are specifically for use with acoustics also
__________________
General Manager GIK Acoustics Europe
DandyCobalt
DandyCobalt's picture
+1 for Camira Cara - excellent stuff for acoustic panels (I made two myself, using 10cm rockwool).
I found that covering with a "transparent" lining material first (I used that cottony dustcover stuff from B&Q) , made it easier to work with the more expensive Camira fabric over the top (rather than directly on to the rockwool and wood frames).
__________________
Main: Pioneer tv + LX85, Sony HW15 Proj, Cyrus DAC XP+/Mono X300/CDXTSE2/PSXRx2, B&W CM8/CM1/PV1D, CA BD751, Virgin TiVo, Inspire Rega t/t, Benz Glider MC, EAR 834P phono amp; Slee Novo Headphone Amp
Second: Panasonic 42" E6B LED, Pioneer VSX-D2011, Kef eggs, Virgin TiVo
RobinKidderminster
All covered ?
__________________
bluebrazil
bluebrazil's picture
if its a rockwool product your after the rwa45 slab is the acoustic one, its itchy tho and i would use knauf acoustic partition roll instead. the rwa 45 comes in more thicknesses tho while the apr is only 25mm 50mm 75mm and 100mm. both should be available in a good builders merchants or anywhere like ccf as mentioned above.
__________________
cyrus cd6s, dab 8, pre xp & psxr, 2*8 powers, chordette gem and dynaudio 52se.
stevebrock
Online
Thanks guys that's plenty of food for thought! 100mm is quite thick not sure the missus is gonna like that, but I need to get some panels to try and get my bass under control.
Where are the best places for the panels
__________________
Rega RP6 / Exact
bluebrazil
 for behind the speakers and sofa i'd be going 50mm, easy then to knock a frame up from 2 by 1. like you say tho finding a printed pannel the missus will like is going to be the biggie.
__________________
stevebrock
Online
Seen some plain green that will blend in ok with our colour scheme, thanks they seem easy and cheap to make
__________________
Rega RP6 / Exact
RobinKidderminster
__________________
jukils
jukils's picture
What kind of acoustic material can besed to stop the noise which is coming because of the traffic.
__________________
Acoustic Sound Control
