Denon 2113 sound to tv problem
5 replies [Last post]
smuggs
smuggs's picture
Denon 2113 is connected to a tv via hdmi sky xbox and blu ray is connected into the input and sound is coming out speakers but amp is not sending sound to the tv is there anything my friend has missed on set up. As he wants at times to just listen to the sound through the tv
__________________
Samsung 46 led tv-denon1909-skyhd-wd tv live -wd my book 2tb nas-apple tv3-xbox360-accer 7540 laptop-dac magic-genie2(2mred)-Montior Audio Br5's Br-LCR Br1's Brw10 sub-ipad(2g)-samsung gs2-akg 450's
bigboss
bigboss's picture
RE: Denon 2113 sound to tv problem
Why would he want to do that? I use my sound system for all TV viewing. Which TV is it? You can probably change the settings on the TV to enable that.
__________________
smuggs
smuggs's picture
I have got it wrong he has bought the amp but the room its going in is a room with no speakers he is just using it as a swither box for wii u xbox sky hd multi room blu ray ps3. But later in the year will be buying some kef eggs.
__________________
bigboss
bigboss's picture
I have never come across this situation of an amp with no speakers! As I said, check TV sound settings.
__________________
smuggs
smuggs's picture
Thanks forthe replys in denon menu in video settings there is a hdmi setting it says tv , avr , both so easy thanks again
__________________
bigdon
bigdon's picture
I have a similar problem with my Denon 2113. Have it connected via HDMI2(ARC) to my Samsung smart tv UE46ES8000 but alas no sound. Have my tv speaker setting to external but no effect. Sound SPDIF output  to PCM. Bluray connection is fine. Is there a setting on the amp or the tv i am missing?
__________________
BigDon
