18 posts / 0 new
Last post
Blazing247's picture
Last seen: 3 years 10 months ago
Why wont my amp blast my lps
Hi all,
I have a technics sl-210 turntable connected to a teac ag-790 amp with a dedicated phono input. The amp is a bit of a monster and will shake the house on cds etc but with the turntable it just wont give anywhere near the volume I know it should. I know that amps without a phono input need a pre-amp to boost the input but this has a phono input. When playing a cd if you have the volume at 30 it is blasting and you can hear it down the road but with lps it needs to be up there to get above quiet. Any advice would be much appreciated. Thanks all
Jim
tomlinscote's picture
Last seen: 2 years 6 months ago
RE: Why wont my amp blast my lps
Looked up the Teac's manual to see if there was a MM or MC setting but it was not much help. Do you know if the TT op is MM or MC because there is a  difference between the outputs one being a llot lower than the other, I think that Moving Coil has the lower output but is less common??
respe's picture
Last seen: 1 year 2 weeks ago
No phono stage (or at least a in built one) that I can think off will take a phono  signal to anything approaching the output level of a CD player. In a few systems the CD output level is just to high. You also have to factor in the output of the cart, they can vary from 1.5 or so to 6 mv. Resultingly the amp itself will need to have more gain applied to bring vinyl up to CD levels through the speakers. It can not therefore give the levels you ''know'' it should from vinyl. From what you have said your neighbours are probably thankful. Smile
Dont know I'm affraid. Like you say there is not much info in the manual. All I can find for the amp is
input sensitivity         PHONO 6.5 mV/22kohms  LINE 230mV/22kohms
frequency response     PHONO 20Hz to 20kHz, +/- 3db  LINE 20Hz to 35kHz -3db
All that means nowt to me but someone in the know may have an idea!
Luckily for all we live in the middle of nowhere
Will fitting a pre amp then increase the volume. It really does need something as if you try and crank up the volume just now it becomes very distorted and the speakers start to hum and vibrate.
altruistic.lemon's picture
Last seen: 2 years 1 month ago
What cartridge are you using?
It is an EPC-P30 cartridge
stevebrock's picture
Last seen: 1 week 6 hours ago
When I far my Rega RP1 TT with Ortofon om5e cart had to have to volume on my Brio between 10-11 o clock, since owning my RP3/Elys 2 I know use the sane volume levels that I use for CD - which is 9 o clock and that's plenty loud enough so it may be the cartridge is shot
Black Gyro SE / SME IV / Primare I32  R32 / AT33 PTG II / ATC SCM11
Does that mean replacing the stylus or the whole cartridge?
Whole cartridge - Ortofon Red 2m would be good
respe's picture
the red is not that clever, the blue is better.
Cartridges don't tend to have a standard output, and that's part of your problem. The second bit is that their output is less than CD anyway, so you'll always need to boost the volume if you want the same level of sound. The other option is to buy a phono preamp that can boost the signal to the same as CD - I think Clearaudio and some others make them.
just ordered a very cheap pre amp to see if that works before I spend any real money on a good one. We will see.
I presume  that if I am using a pre amp I shouldnt use the phono input on the amp as it will be too much input power, or does it not matter?
RobinKidderminster's picture
Last seen: 2 months 3 weeks ago
Blue & red have double the output voltage of your existing model but very different budget
Yamaha V2065. MS Mezzo 5.1 Panasonic 42. Sony BD. Garrard 86SB. WD Live TV. SkyHD.
http://www.whathifi.com/forum/home-cinema/lounge-hc-signature-update-bass-traps
Pages
Log in to post comments
