18 posts / 0 new
Last post
gbhsi1's picture
tonearm inner cable
Hi all, was replacing my cartridge with a new cartridge when I accidentally broke one of the very fine inner tonearm cables! doh!
I can by another from Hendley Designs for £7.50 but is it easy to install a new on? obviously I will be more careful this time..or do I have to get a specialist to install it?
gbhsi1's picture
RE: tonearm inner cable
spelling mistakes galore! whoops!
gbhsi1's picture
Can anyone provide some help or idea?
nopiano's picture
Last seen: 2 days 3 hours ago
If it is one tag, mounted within the headshell, then you should be able to replace it easily - with care, and maybe some fine-nosed pliers, ot tweezers.  That's what it sounds like for £7.50.
But if your arm is wired through to the arm base, or even through to the cables that lead to your pre-amp, you will probably need it done professsionally.  Worth asking Henley - is it is Pro-Ject model, perhaps?
It would help to say what arm/TT you are using!  That may be why no-one replied sooner...
Krell CD and amp, Michell/Rega/Grado for LPs, Hitachi and Sony tuners, Nakamichi cassette, SBT streamer, Chromecast audio, Sonus faber Concerto Grand Piano spkrs. Qobuz > iPad > AudioPro Allroom Air One
gbhsi1's picture
Hi, thanks for the reply. It's a pro-ject experience 2- is that hard wired or just simply connectors?
nopiano's picture
Well, I don't know from memory, but I looked here: http://www.project-audio.com/main.php?prod=xperiencesp&cat=turntables&lang=en
and it says:-
"The internal wiring consists of flexible high-purity copper from the headshell right through to the gold-plated phono sockets."
So, if you do indeed have a Pro-ject 9c tonearm, I'm not sure what you are getting for £7.50, but surely not the whole internal wiring set.  However, I suppose you might still have links from cartridge to within the headshell.  Can you not see if there are tags before the wires disappear up the arm-tube?  If there are tags, then you are OK.
gbhsi1's picture
when you say tags what do you actually mean?
John Duncan's picture
Last seen: 1 week 4 days ago
The four little spade-like connectors on the end of the wires at the headshell.
Moderator: john.duncan.whf at gmail dot com
System burgeoning
gbhsi1's picture
Just received the inner cables from henley designs.....it has to be hard wired on one end! ....don't think I should attempt that....:-/
gbhsi1's picture
chebby's picture
Last seen: 2 hours 52 min ago
Anything involving internal wiring is going to need to go your dealer (and will almost certainly go back to Pro-ject/Henley to deal with) unless you have expertise in this area.
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
chebby's picture
Sorry I was still typing that as you posted.
gbhsi1's picture
Ha ha! Hopefully the fellas in Sevenoaks can do it for a small fee Smile
nopiano's picture
gbhsi1 wrote:
Ha ha! Hopefully the fellas in Sevenoaks can do it for a small fee :-)
If not, and Henley cannot help, then try J7 at audio origami (I don't think I'm meant to put a link here, but you'll find them).  They seem to be able to rewire anything.
Anonymous's picture
Did you get this sorted? What was the solution? Ive just done the same thing with my Project RPM 10  :cry:
gbhsi1's picture
sorry to hear that - dropped off my turntable to sevenoaks who then sent it to pro-ject, total cost was £50. A costly mistake! not sure if your turntable is hard wired though..?
Pages
Log in to post comments
