6 posts / 0 new
Last post
alchemist 1's picture
Last seen: 2 weeks 1 day ago
Denon dl103 V Otofon 2m blue
   Thoughts or experiences of  either cartridges.
   To be used on Roksan Tabriz arm.......
chebby's picture
Online
Last seen: 3 hours 36 min ago
RE: Denon dl103 V Otofon 2m blue
I have heard a friend's DL103R on his Rega P3-24 (Primare amp + ATC SCM11 speakers).
At the same time he bought that, I owned a Rega P2 with Ortofon 2M Blue (with Nait 5i + Naim nSat speakers).
So therefore I heard both set-ups in different rooms, with different music and different systems. (Even the DL103R is different to the 'original' DL103 that you are asking about.)
Not very useful i'm afraid.
Obviously I preferred what I was listening to with my P2/2M Blue/Naim system (I would wouldn't I?) but the DL103R had it's moments.
The DL103 is a big old slice of history (designed for Japan's national radio broadcaster in 1963) and modern stylus profiles have come on a long way since.  (The DL103 has a spherical stylus and tracks at 2.5 grammes.)
Personally I would go for neither nowadays and opt instead for a Shure M97XE for about £75 (Stylus replacement about half that,  so cheap enough to get in a brace of spare stylii and still spend less than buying one Ortofon 2M Blue.)
iPad Mini 3 • iPhone 6 • B&W P3 • Mac Mini • Apple TV3 • Quad Vena • Pro-ject Tuner Box S • Audio-Note AX-Two
   Merci  beaucoup...Chebby
respe's picture
Last seen: 1 year 1 month ago
they really are chalk and cheese. I can not understand what the fuss is about with the 103, unless you listen to a lot of Jazz on vinyl, in which case it may make some sense. As one is a MC and the other a MM, what phono stage would you be using?  As a passing thought, do you have the 103, or would it be a new purchase.
                     I have neither, have only listend too the otofon.
                      Working on simular priced cartridge.
                      Will be for a future purchase [hopefully] using my tabriz on a gyro se.
Al ears's picture
Last seen: 1 day 41 sec ago
I would tend to agree with chebby in that the Shure is probably a better choice than the bog-standard 103.
I have used a 103R on a Tabriz arm with Radius turntable and, correctly set-up with a good phono preamp it really is a stunner for the money. I cannot comment on the Ortofon as have never heard one in any set-up.
Like respe says if you go for the denon you are going to have to factor in the cost of a phono stage of some kind, which can often defeat the object. Better to by a better quality moving magnet if your amp already has a phono stage built in.
Motto: Never pay full price for anything, there is always room to haggle!
Tom Evans Audio Design amplification / Acoustic Zen Adagio speakers / Dr. Feickert Analogue Woodpecker-SME310 / Oppo 105eu
Log in to post comments
