Home Cinema Surround Sound 7.1
9 replies [Last post]
jpm
jpm's picture
I am about to set up a home cinema in a room that is undergoing a major overhaul, including new ceiling and plaster. I want to future proof the system so was thinking of putting in 7.1 from the outset. I was planning to have wall mounted speakers at the centre and front. I am considering having ceiling mounted speakers at the side and rear. My budget for the whole system is about £5-6k.
My question is what sound system or speaker components would you recommend with in-ceiling speakers at side and rear. I am assuming that from my total budget I would be looking to spend £1000-1500 on speakers.
If anyone is able to recommend the other components to sit alongside the sound system that would be great! (Blu-ray 3D, Receiver, 3D projector)
Chewy
Chewy's picture
RE: Home Cinema Surround Sound 7.1
You're budget will give you a fair few options, but my single piece of advice is forget about in ceiling speakers - they will compromise the quality of your surround sound system far too much. A much better option would be to use the same inwall speaker you use for the LCR, for the four surrounds (or at least a lower spec version of them).
Is your room a dedicated home cinema room?
__________________
JVC X70 | Beamax 105" M-Tensioned Screen | PMC MB2i Fronts & MK SS150 Surrounds (7.1) | Paradigm Signature Sub 1 | Primare SP32 | 3 x AB Systems 11000SE Monobloc amps + 6500SE 6-Channel amp | Oppo BDP-95 | UnRaid 16TB Media Server | Netgear NeoTV 550 | PS3 | Darbee DVP5000 | Sonos Multi-room system
Son_of_SJ
Son_of_SJ's picture
Online
Not sure about the other components, but with your budget you should be getting a Yamaha Aventage RX-A3010 receiver, which is a top-quality item. Stocks are disappearing like snow in June, but you an internet search should still be yield one for about £1,100, much reduced from its previous price of about £1,600 because it is about to be replaced (by the RX-A3020). And, this is another argument against fixed ceiling speakers, this Yamaha can drive nine speakers, or even 11 if you add a separate stereo amplifier. And it can drive two subwoofers also. A great machine, but it does weigh about 19 kg! You'll also see highly favourable reviews of it in What Hi-Fi and elsewhere.
jpm
jpm's picture
Thanks.
The room is 14m long and 4.5m wide - we will be using one end of it as a home cinema - about 6m in length.
Looking at what I assume is your home cinema set-up at the bottom of the post:
How does the quality of a tensioned screen compare with a fixed screen?
AVOnline
AVOnline's picture
No problem with decent tensioned screens - but generally expect to pay more for a screen of the same quality than you would for a fixed screen. In-ceiling speakers make quite acceptable surround speakers if there's really no option to install in-walls or some on the wall. Take a look at the Monitor Audio C265-FX for example, great partnered with some W280-LCRs up front. Assuming your budget was for the installation speakers, or do you need a sub in that price too?
__________________
John Anderson @Audiovisual Online
Son_of_SJ
Son_of_SJ's picture
Online
It wasn't clear from your unquoted reply immediately following my posting that this question was directed at Chewy, not at me.
I had hoped that my contribution at 9:28 pm last night would be useful, but perhaps not.
jpm
jpm's picture
Sorry. Looking in to the option you outlined. Thanks. All advice welcomed and helpful so far.
jpm
jpm's picture
Thanks. Need a sub. Budget was for whole system and not just speakers - sorry for any confusion!
sta99y
sta99y's picture
If you sign up on another well known avforum you can get the Yamaha RX-A3010 for £999 that's half price of its original RRP!!! Oh in Titanium as well.
__________________
Samsung PS50a456-Cambridge audio Azur 650BD-Yamaha RX-V2065-BK XXLS400-Monitor Audio Radius 180 fronts/surrounds-225 centre-XBOX360-ATV3-Logitech Harmony One-Gale Hyper-Latz 250 spk cable-IOXS Interconnects-iPod 30gb video-iPhone 4
Cptbaker1980
Cptbaker1980's picture
Hi, if your building from scratch I'd be tempted to just put terminals in the walls and ceiling or even floor. A front high left and right presence and rear terminals would be good.
the last thing your'll want is to set up speakers in the wrong place, terminals will give a bit of flexibility, and let's face it your not going to just build it and leave it there's going to be tweaking and upgrading aplenty.
I have a large room 10x10meters and have the rear back surround terminals under my sofa in the middle of the room and just get them out on stands when it's viewing time, very little is in 7.1 anyway so I only have them out for big blockbuster type films.
Just some ideas.
__________________
Wharfedale 9.6/9.1/cc/sw150 and tiny little moviestars for the very back, Yamaha AS-500 and RX-667 Cambridge audio CD-10 Sony bdps370 Panasonic tx-32v10b, 2004 Rioja and a small cheese board.
