Standmount choice
7 replies [Last post]
paulsue38
paulsue38's picture
Undecided about which speaker to choose in a small room 4m x 3m. Looking for a well balaced speaker with a good mid band  (not overly bright)  to be used with a Roksan Kandy 3. / Roksan Caspian Tuner/ Cambridge Audio CD player. Musical taste varied. I have considered
Spendor - S3/5R - great midband, and good with voice but is it a good all rounder and is it more suited to classsical alone?
Spendor SA1 - Not sure about the finishes. My wife likes the Zebrano but I am not so keen. Not sure why they dont do this speaker in a more conventional Cherry or Oak?
PMC DB1i or TB2i - Some mixed reviews and the price difference between the smaller and larger models seems small. Is the larger model better value?
Proac - no idea were to start with Proac some reviews appear to point to a bright and foward presentation?
Any comments or advice would be really helpful.
Best wishes
Paul
__________________
Roksan Caspian Tuner, Roksan Kandy L111, Cambridge Audio 650, Spendor A3
MUSICRAFT
MUSICRAFT's picture
Online
Re: Standmount choice
Hi Paul
I'll recommend ATC's SCM11 monitors.  The SCM11's detailed, superbly balanced right across the board and also work well in small rooms.
All the best
Rick @ Musicraft
__________________
Musicraft (Derby), Specialist Hi-Fi/AV & Multimedia Dealer
good accurate audio monitoring and good sound reproduction to all Smile
Singslinger
Singslinger's picture
A hifi enthusiast friend and I just a few days ago did an A/B comparison between the Spendor S3/5R and SA1 and concluded that the SA1 was the better speaker - more detail and bass, particularly at low volume. Of course, it costs quite a bit more, especially if you add the matching stands. As for finishes, the most conventional would be satin wenge which resembles dark mahogany or rosewood.
PMC DB1i - I own this speaker and find it very easy to live with. Plenty of bass (more than the SA1), very detailed and it's not difficult to drive, ideally suited to a small room. The amp I use is a Musical Fidelity A1 (rated at 36W).
ProAc - I still own a pair of Response 1 SC speakers, bought 17 years ago. To be honest, I think it's superior to both the Spendor and PMC, even after all these years. Very sweet, unfatiguing sound, which is ProAc's trademark. It's been updated now, replaced by the Response D1. I would audition the new D1 as well as the smaller Tablettes.
The other speaker in roughly the same price range I'd highly recommend auditioning is the Elac BS 243, which comes in a cherry veneer or piano black. Elac is a German brand, not very well-known in the UK but it looks like they might be making an effort to change this because this model was reviewed - very favourably - in the Oct issue of Hifi World. I've heard this speaker and I think i offers fantastic value for money - the ribbon tweeter gives a very sharp and clear treble while the bass is quite unlike anything I've heard before from a speaker that size. The mag review gave Atacama Audio as Elac's UK distributors.
Hope this helps. Good luck and happy listening!
jaxwired
jaxwired's picture
Having owned (briefly) ATC SCM 11s, I would recommend the PMC DB1i over the ATC.  The PMC has a more balanced sound with more satisfying and articulate bass, even given it's smaller size.  To me the PMC is more musical and more entertaining.  I can't imagine someone being unhappy with the DB1i.  Although, I agree that for the money the TB2i may be a better value.
__________________
iTunes Lossless -> Airport Express -> Benchmark DAC2 HGC -> Belles 150a REF V2 -> Dynaudio Focus 340-> Chord Cables
reggaedave
reggaedave's picture
splendor SA1 or my favs the rega RS1 are both brilliant sounding speakers, really put a lot of others to shame...
__________________
Too many things to list but spent a fortune!
paulsue38
paulsue38's picture
Many thanks for the detailed reply that is really helpful I will check out the Proac D1.
Paul
__________________
chebby
chebby's picture
MUSICRAFT:
If you look at the size of the speakers the OP is considering,  I would have thought the SCM7s would be a better choice than the SCM11s in a small room. (Cheaper too.)
I also agree that (from experience of both) that the PMC DB1i is a preferable listen than the somewhat 'shouty' and utterly ruthless ATC SCM11s.
The S3/5Rs are nice (and they can do that 'holographic' thing with the right system and music) but a little too warm and smooth and refined for me. Ok in a small room with chamber classical/jazz/acoustic and vocal material at reasonable volume levels, but lose it to the SA1s for sheer verve and swing.
If you are using Naim in a small room, then their own n-SATs (£790) are excellent for this size of speaker. I haven't heard them outside of my own system though. I have no idea how they will perform with Roksan gear.
The Rega RS1s can do 80+ percent of what any of these speakers can achieve for only £399 so be careful not to ignore them.
__________________
Marantz M-CR603 + AirPlay • Rega R3 loudspeakers • iPhone 5 32GB • iMac • Apple Airport Extreme 802.11n • Panasonic TX-L32D25B • Sony BDP-S390 • Ruark Audio R1 Deluxe • Humax HDR-Fox T2
TheHomeCinemaCentre
TheHomeCinemaCentre's picture
The TB2 has a very different sound to the DB1 but both are very good speakers - you really need to hear them to decide which is right for you.  As a slightly cheaper alternative you may want to consider the KEF Q300's and spend some spare cash on speaker cables / interconnects. Despite the low price compared to the rest of your selection they will work nicely with the Kandy.
Another good option is the Dali Ikon 5. It may be a floor standing speaker but it has a very small footprint and with the ribbon tweeter it has a glorious top end.
__________________
Nick
The Home Cinema Centre
