ATC SCM 50
16 replies [Last post]
ebentjerodt
ebentjerodt's picture
Hi all,
I am thinking to buy the ATC SCM 50 passive but I got an offer for a second hand ATC SCM 50 Active.  the buyer told me that a active speaker will be always better as the passive (same mode) as the amplification adn crosover was done like a suite after your size.
is this true?  will I have a better result wiht the active and for exampe a USD 4.000 pre amp rather than the passive wiht my Gryphon Diablo?
waht do you think?
I can buy the active for USD 14.800.
thank you in advance
kr
Eduardo
__________________
OLIVE 06 HD/ CHORD QDB76HDSD DAC / CHORD PRIMA PREAMP / ATC SCM50 ASLT / MERIDIAN i80
BenLaw
BenLaw's picture
RE: ATC SCM 50
That seems expensive for a second hand pair even latest spec and in good condition. But yes IMO the active version will be substantially better than the passive.
__________________
HiFi   /   A/V   /   Bedroom
ebentjerodt
RE: ATC SCM 50
Thank you Benlaw.
prcie in chile for the new once is USD 19.600, so about USD 4.000 lower.
kr
Eduardo
__________________
MattSPL
MattSPL's picture
RE: ATC SCM 50
Could you import a pair of scm50asl's from the U.K?
__________________
Arcam Cd33 > Matrix Quattro Dac > Digidesign RM2's on Partington Broadsides > Velodyne DD12 > And some mains cables that make it sound better Smile
ebentjerodt
RE: ATC SCM 50
yes, but then I have to pay a lot of taxes to get them in to tyhe land.  about 40% plus the transport.
__________________
MattSPL
MattSPL's picture
RE: ATC SCM 50
Ok, sounds like Tax is expensive for you, but might be worth looking into. Used, nearly new scm50asl's can be had for around £6,500.
__________________
lindsayt
lindsayt's picture
Online
RE: ATC SCM 50
The price seems too expensive to me. That's only a 20% discount off the new price, which I don't think is enough for 2nd hand kit. Aim for at least 50% off the new price.
For $14,800 you could buy a 2nd hand pair in the UK, fly to England and fly back again with them, or possibly bring them home on a couple of cruise ships, and still have a lot of money left over.
And of course someone selling active speakers would say that active is always better, wouldn't they? In reality it's a big fat "it depends" on whether active or passive sounds better for any particular speaker. For ATC 50's I'd say go active if you can get a good deal on an active pair.
ebentjerodt
RE: ATC SCM 50
so, finaly I deside not to go for the acive speakers as I really love the Gryphon Diablo.  Unfortunately I was not able to get second hand passive ATC 50 and the new once are really a bit to much for now,  so I have finally 3 speakers to decide
1. ATC SCM 20 TOWER
2. PMC FACT 8
3. SONUS FABER CREMONA M
waht do you think?
kr
Eduardo
__________________
MattSPL
MattSPL's picture
RE: ATC SCM 50
1. ATC SCM 20 TOWER
2. PMC FACT 8
waht do you think?
kr
Eduardo
Can you audition them?
I see you have scm19's. The scm20's will be very similar to the 19's, but have better high frequency performance. They also have a slightly better bass performance due to more solid build.
__________________
BenLaw
BenLaw's picture
RE: ATC SCM 50
Tho overall if you want to move away from the sound of the 19s the 20s are unlikely to be for you, they will have very similar characteristics.
I found the PMCs very dry, but maybe this is the sound you're after. Don't know the SF.
__________________
Bodfish
Bodfish's picture
RE: ATC SCM 50
I used to own the Fact 8's but didn't get on with them in the long term and replaced them with my current speakers. I'd echo Ben's comments - are you trying to move away from the ATC 'sound' or do you want more of it?  If so, the 20's would seem to be the logical choice (if you can't audition).
But something tells me the Gryphon and SF would be very special indeed.
__________________
NaimUniti | Rega RP8 | Harbeth Super HL5
steve_1979
steve_1979's picture
RE: ATC SCM 50
Hopefully AlmaataKZ will be able to expand on this further. Smile
But I think that he has listened to both the active and passive versions of the SCM50 together before buying the active version because it sounded better.
__________________
PC > AVI Neutron Five 2.1
BenLaw
BenLaw's picture
RE: ATC SCM 50
Edit: deleted as wrong!
__________________
ebentjerodt
RE: ATC SCM 50
Yes, I heard the 20 but I was not convince to change them for my 19. they were quite similar and I was looking for a bigger sound as my living room is quite big.  I heard the PMC  (and really like them) but not with my system. Tomorrow the dealer is bringing them to my place to make an audition so this will be very revealing.
I have not heard the Sonus Faber yet,  but the price I am getting for the PMC make it very difficult to look away!
kr
Eduardo
__________________
AlmaataKZ
AlmaataKZ's picture
RE: ATC SCM 50
I heard the cremona and fact 8. All imo: Cremona has very pleasant, warm sound with very slightly emphasised treble, finish is superb. Fact 8 are very boomy, bloated mid bass, very low vfm (you do not get much in terms of drivers for a lot of money), the cabinets and finish are superb. I also heard active and passive atc 50s side by side at the Heathrow show. This was my very early days in terms of exploring actives. I remember I did not hear a night and day difference, very little in fact, but I remember passives seemed to have a bit more bass which I later understood to be boom.
i have never heard atc 20s.
if you are looking for good actives a bit cheaper than atcs, have you considered avi adm 9s or 40? I heard the 9s and was very impressed. They have very clear, dynamic sound with well controlled bass. Given the size, granted, not as powerful as atc 50s but still the adm 9s are superb imo and have more than enough power.
Have not heard the 40s but they should be good too. Get more info on avi forum.
ebentjerodt
RE: ATC SCM 50
AlmataaKZ,  unfortunately we do not have the adm speakers in Chile.  I finally deside to stay wiht passive speakers as I really like my Gryphon. so the options will be The Cremona M or the fact 8.  waht will you choose between this 2?
Eduardo
__________________
