4 posts / 0 new
Last post
mat.w.'s picture
Last seen: 2 years 8 months ago
Hard drive and power supply adaptor creates speaker hum
Hi
I have ripped my CD collection to an external hard drive and play using Musichi software on a netbook and Cambridge DAC via a Quad amp to Quad ELS speakers. Not the easiest to set up but done now. However I am suddenly getting speaker hum when switching the power supply adaptor on and even more with the hard drive on. Its a new problem, all worked well at first. #
I have isolated each and every component and its those two items that are the issue. I assume its some form of feedback. I have swapped power adaptors and hard drives but the problem still returns.
Any solutions or explanation?
John Duncan's picture
Last seen: 4 days 6 hours ago
RE: Hard drive and power supply adaptor creates speaker hum
This is quite common - how is the netbook connected to the DAC?  And is it the external hard drive power supply or the netbook's itself which is causing the problem?
Moderator: john.duncan.whf at gmail dot com
System burgeoning
iMark's picture
Last seen: 5 days 4 hours ago
Do you have a tuner connected to your amp? You may have groundloop hum.
If you have a tuner connected, try detaching the aerial lead. If the aerial causes the hum, you could try a ground loop insulator.
Do you get hum if the power supply on the netbook is detached?
In a previous setup I had a terrible hum when my stereo receiver was connected to the cable radio socket an my computer was also connected to the receiver. I solved this by putting a filter cable on the aerial cable.
Pro-Ject 1Xperience Comfort (OM 2Red), Yahama R-N602, Sony UHP-H1, Sony TV, Humax DVR, Infinity Overture 1 speakers. Range from very cheap to expensive cables.
scene's picture
Last seen: 18 hours 20 min ago
You could try some clip on ferrite cores around the power cables (if they haven't got them already) - this may help.
AV: Marantz SR7009; Monitor Audio RS-LCR, Silver 8i, RXFX; BK XXLS400 Sub; Pioneer KRP500a; Sony BDP-S760
HiFi: Arcam A85; AE Compact 1; Arcam DV79 (as CDP), ProJect Debut II
Log in to post comments
