Alternative to Airport Express?
6 replies [Last post]
srmatthews
srmatthews's picture
Hi, if Airport Express does what I think it does, (i.e. I have the PC 4 metres from the hi-fi and would like to be able stream music to it) the AEX seems oddly good value for money, however, a quick Google suggests it's not the best of bedfellows with Windows, are there any similarly priced alternatives? And would they go above 16bit? I'm connected via powerlines around the house if that's germane.
Thanks, Steve
Juzzie Wuzzie
Juzzie Wuzzie's picture
RE: Alternative to Airport Express?
You shouldn't have an issues with an AEX on a Windows based system.  Much like Vegemite, AEX are either liked or loathed by people.  I am a fan, although would suggest for £20 more, to get an Apple TV (unless you need either a) the onboard DAC or b) LAN ability of the AEX).
__________________
Living Room: Samsung 40C7000; Oppo BDP-103EU; Onkyo SR308; Apple TV3; Airport Express; Sky HD+; Jamo A102 HSC5; Naim Nait 5i-2; Neat Iotas; Chord / Wireworld / QED / TCI interconnects and speaker wire; Harmony 550 universal remote; Tacima mains conditioner Portable: Shuffle (1G); iPad (1G); iPad Minil FiiO E1; AKG450; Grado SR60i; Sennheiser CX300II; custom Ultimate Ears Car: iPod Classic 120GB
jjbomber
jjbomber's picture
Roku for £50 will do the job better than AEX. Squeezebox if you want the best in that sort of price range. You can also bluetooth the signal with a u-play from QED.
amcluesent
amcluesent's picture
Airport Expres needs a copy of iTunes running somewhere on the network. It's DAC is weak. Apple TV resamples everything to 48Khz which is fugly for CD rips.
__________________
Stello CDT200, Squeezebox Transporter, Myryad MT100, Audio Analogue Maestro Settanta REV2.0, Sonus Faber Guarneri Homage  · Squeezebox Touch, Quad FM4\34\306, Sonus Faber Concertinos · Squeezebox Controller
srmatthews
RE: Alternative to AEX
Thanks, never occurred the ROKU would have that secondary use, their website is a bit light on tech detail, I assume it might struggle with >16bit audio?
srmatthews
looks like the Boxee will do hi-res FLAC too, http://www.squidoo.com/flac anyone any experience of this? Currently £99 at Amazon, a lot cheaper than a Squeezebox
bigboss
bigboss's picture
__________________
