What subwoofer should i buy
10 replies [Last post]
sceep
sceep's picture
Hi everyone.
I want to buy a subwoofer for my system which is not something special. My budget is 300 euro. The sub will be connected to Yamaha HTR6230. I'll use it for movies and music - jazz and chill. The room is 24m/2. I have only front speakers - Yamaha NS 8900.
What would you say about Dali Basis 100 ? Is there anything better for this money?
Cheers Smile
bluedroog
bluedroog's picture
RE: What subwoofer should i buy
Where are you based?
Try the BK range of subs, the entry level Gemini II and has better specs than the sub you link, also a 10" driver but 150w power, I suspect the cabinet has better build qulaity and bracing too just judging by the looks. The Gemini is is just £215 and also availible in a choice of finishes.
If you can stretch the the XLS200 it will give you that little bit more, the XXLS400 better still and that is what I use.
sceep
sceep's picture
I'm from Bulgaria but it's not a problem to buy the sub from UK.
I'll take a look on the BKs
sceep
sceep's picture
Anyone else? Smile
sceep
sceep's picture
What about Klipsch KSW 10?
bluedroog
bluedroog's picture
At the price point, still BK.....
richardw42
richardw42's picture
Yes, BK + 1
__________________
TV room : Samsung 60" plasma-ATV3, Denon DBP2012UD-Yamaha RXV3067-AVI ADM9RSS,MA RSW12,/Sonos ZP90 via optical, Sky+ HD & Sky Connector, PS3
HiFi : Sonos ZP90 - AVI ADM40
Bedrooms : 2 x Sonos Play 3
Ipad for Sonos & Spotify
BigColz
BigColz's picture
At this price point nothing will beat the BK from what i've heard read.. Never seen a product with hundreds of recommendations/perfect reviews and not a bad word said.. They used to make the parts for companys like REL and a sub of the same spec is twice the price from these brands as you are cutting out the middle man and buying direct! I will be buying one blind next year and if by some miracle you don't like it you can sell it at a minimal loss.. Also it comes with the cables you need and looks cool.. Win win win IMO
__________________
Electrocompaniet PI 2 | Naim ND5 XS | Chord Epic | ProAc Studio 115
bluedroog
bluedroog's picture
I think buying subs blind is far less risky than most audio components, in my experience they have less of a character and you can read a lot in to the specs alone assuming it is well made in terms of bracing etc., which the BKs are.
BigColz
BigColz's picture
Agreed.. They do what they do. They're either good musically by accuratly producing the different frequencies or they are more 'one tone boom' or if they are underpowered or under 10'' can distort as they're being overworked and can't go as low.. The amp is designed to run that one frequency range
__________________
CnoEvil
CnoEvil's picture
Yup!
IME Go with brands that specialize - BK / Velodyne / Rel / Paradigm / SVS etc
-  ATC and KK are also excellent
I prefer sealed subs.
IMO. BK are the best VFM
__________________
"Everything has been said before, but since nobody listens we have to keep going back and beginning all over again."  André Gide
