Roksan Kandy 2 AMP 'To Bright'
162 replies [Last post]
The sewage man
The sewage man's picture
My equipment collection is on the bottom of this tab.
My question is since I bought my Roksan Kandy 2 a few days ago, it sounds really bright, almost to the point of piercing.  Don't get me wrong,the music is clear and sharp and realistic.  I have played with the 3 settings however on the Dacmagic, but it is still bright sounding.
What the music does lack is warmth.  Is their anything I can do to compensate for the brightness? Is it the Dac?
igglebert
igglebert's picture
Re: Roksan Kandy 2 AMP 'To Bright'
Give it a month to settle in. You'll probably find that it loses its sharpness. Very subtle fine tuning can be achieved later on with interconnects but you have a pretty revealing one. Also, keep the speakers straight out and not toed-in to avoid treble 'beaming'.
spooks1982
spooks1982's picture
Not sure it's the AMP that is making it sound bright, I have this
amp and it certainly isn't as you describe in my system. Like the
previous post suggests, it could be because it is new - give it some
time to break in and i'm sure you'll be loving the sound it is capable
of producing.
I have a quick question for you actually,
slightly off topic but related to your kandy amp. Is the front of the
volume knob on your amp perfectly arched? Mine has a tiny recess in the
middle - I thought it might be a dent but it looks to perfectly formed
to be a dent and is only slightly visible. Weird question I know. Smile.
__________________
I'm outta here! Hi-Fi sold, no more box listening for me!
matthewpiano
matthewpiano's picture
Give it some time to run in and then look at switching your speaker cable from QED to Chord. Rumour 2 matches well with the Chameleon.
__________________
Rega RP3/Elys 2 >> Cambridge Audio 540P phono stage, Squeezebox Touch >> optical input on Denon RCD-M39DAB >> Q Acoustics 2020i. Beyer Dynamic DT770PRO
hi fi newbie
hi fi newbie's picture
Give it a few weeks and if you still feel the same, then it's likely you don't like the upsampling on the dacmagic, I have heard this with my beresford and it never sounded piercing in the least.
The sewage man
Thank you for you responses.  Can speaker wire really make that much of a difference?
Tarquinh
Tarquinh's picture
Not really, think 0.001 procent.
plastic penguin
plastic penguin's picture
The sewage man:
They make subtle differences, but don't buy any add-ons until your amp has fully bedded in.
What's the accoustics of your room like? Do you have hard flooring? if so, go and buy rug and a bookcase after a few weeks (make sure your kandy has run-in).
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
the record spot
the record spot's picture
The sewage man:
Yes, but not to the same degree as changing core components. I use Audioquest Type IV, which is a single core biwire cable, very nice with the current setup and it's been in place for about ten years or so. No plans to shift it currently. If you want a warmer sound, I'd see if you can loan some similar cable from a dealer to try out at home. Audioquest seem to do warmer sounding cabling (I use their Copperhead interconnect between amp and CDP and it took the edge of an overly bright system in one fell swoop) so I'd recommend them wholeheartedly.
__________________
Onkyo TX-NR818 / Tannoy Revolution DC4 / Marantz SA7001-KI
Bin Clankem
Bin Clankem's picture
If the sound got too bright when you changed the amp, then it's the amp.  Don't know the Kandy 2, but the Kandy 1 wasn't a very good product.  What amp were you using before?
fowler
fowler's picture
Bin Clankem:
do you mean the L3 kandy ? if so what isnt good about it ? its a fantastic bit of kit .
__________________
ATC SIA2 150,ATC SCM40,CHORD QBD76.MK 950,SS150,PARADIGM SEISMIC 110,PIONEER 428XD,OPPO93...ROTEL 1575,ONKYO 5509,PANASONIC VT 50 COMING THIS YEAR.
Bin Clankem
fowler:
Bin Clankem:
Didn't like it at all when I heard it - YMMV.  I think with the wrong speakers it could be very bright and harsh.  Amp/speaker matching is important!
igglebert
igglebert's picture
Bin Clankem:
fowler:
Bin Clankem:
That was my observation of it too but a lot like it!
The sewage man
Once again thanks for all your answers.  However it has opened more questions?
 I had a friend around today who said the music sounded 'sharp' that was his expression of bright.
Can speakers make it sound that sharp 'bright'?  What speakers would you reccommennd under £1000?
How come their is no graphic equalizer on the amps these days?  Would a Graphic Equalizer sort the problem out?
Tarquinh
Tarquinh's picture
How did the Mezzos sound with your previous amp?
batonwielder
batonwielder's picture
What amplifier were you using before the Roksan? Was it not bright then?
