10 posts / 0 new
Last post
tom2b's picture
Last seen: 4 months 2 weeks ago
Virgin Media upgrade to HD box
Till recently, I have used an old 32"Panasonic CRT TV on Virgin media cable (SD)box, and found the picture quality''very acceptable'.
I have now bought a Samsung UE37EH5000, and unsurprisingly the picture quality ranges from poor to acceptable~this is supposed to have Freesat HD, but this presumably is not routed through the VM box.
The answer to this seems to be to get a VM HD box, and I will then enjoy fabulous HD quality.....?!, or are there any other considerations??
hammill's picture
Last seen: 1 week 5 days ago
RE: Virgin Media upgrade to HD box
Surely the answer is to get a satellite dish and tell Virgin you don't need to pay them anything.
laserman16's picture
Last seen: 1 month 2 days ago
Well, if you want to use the Freesat HD tuner installed in the TV you will need a Satellite dish put up and connect the TV direct to that.
Smile Beaten to it. Smile
tom2b's picture
Thanks for reply guys,
Was Really looking for confirmation that if I upgrade to an HD box, that I will then have an improvement in picture quality, both for SD channels and HD channels. ..?
Well, you did also ask "or are there any other considerations??" Smile
f1only's picture
Last seen: 1 day 15 hours ago
The SD channels will be upscaled by the box & the HD channels can be output up to 1080i
A/V Pioneer SCLX59 Speakers B&W 683 S2 685 S2 HTM61 S2 Centre 686 S2 For Atmos x4 ASW610 Sub x2 TV Calibrated 4K Panasonic TX-50AX802B BDP Sony PS3 & PS4 Pro HDMI Monster ISF2000HD Virgin Tivo Netgear ReadyNas104 12TB
Anonymous's picture
RE: Virgin
If you want HD, get Sky. Far better choice of HD channels than Freesat or Virgin.
Anonymous's picture
Hi. I'm thinking about buying the 37" Eh5000 and was wondering if you recommend it?
bigboss's picture
Last seen: 1 day 6 hours ago
I bought the 32" EH5000 for my sister-in-law. It's a brilliant TV for the price. I was gobsmacked at the performance after tweaking the settings a bit.
Log in to post comments
