onkyo 818 12v trigger
3 replies [Last post]
clarke359
clarke359's picture
Can the 12v triggers on the onkyo 818 be used to switch on projector and sub both have trigger inputs
if so how thanks
__________________
onkyo 818,
B&W CM9
B&W cdm ,
Panasonic ptae 5000,
REL strata 5
BenLaw
BenLaw's picture
RE: onkyo 818 12v trigger
Definitely should be possible. Connect jack to jack leads between the triggers and then turn them on in the onkyo menu. May need a switch off and on again to start working.
__________________
HiFi   /   A/V   /   Bedroom
clarke359
clarke359's picture
Hi thanks for that will have a go i found trigger settings in the panasonic menu but can only see blacked out zone controls in the onkyo menu.
__________________
onkyo 818,
B&W CM9
B&W cdm ,
REL strata 5
BenLaw
BenLaw's picture
Check pages 78 and 59 of your manual. It looks like the triggers are designed for control of additional zones. If those zones can be left permanently on (ie they come on when you turn the av receiver on) then you should be fine.
__________________
