B&W CM8
11 replies [Last post]
DandyCobalt
DandyCobalt's picture
Setup
__________________
Main: Pioneer tv + LX85, Sony HW15 Proj, Cyrus DAC XP+/Mono X300/CDXTSE2/PSXRx2, B&W CM8/CM1/PV1D, CA BD751, Virgin TiVo, Inspire Rega t/t, Benz Glider MC, EAR 834P phono amp; Slee Novo Headphone Amp
Second: Panasonic 42" E6B LED, Pioneer VSX-D2011, Kef eggs, Virgin TiVo
El Hefe
El Hefe's picture
RE: Your system
Nice set up dandy. What are those black rectangular item underneath the speakers??
I assume the radiotor is not functioning anymore.
How is the sound like when you set up your kit in the corner like that?
__________________
HiFi: ClearAudio Concept TT, Musical Fidelity M6i and M6 DAC, M1s (CDT, CLiC, ViNL), Onkyo TA2600, SONY MDSJA20ES MDP, ProAc D18 with full Siltech cabling.
HT: Samsung UA55B7000 LED, OPPO BDP 95-EU,Marantz DV4003, Yamaha RX-V2067, Philips DVDR7300H, Infinity Primus Center, Wharfedale WH2, SW15 Sub, Mission M34i with full QED cabling
Bedroom: BRIK Audio BT Stage, Bose WAVE Music Sytem III
HeadFi: Alessandro Grado MS Pro, Bryston BHA-1 headphone Amp.
Office: iTunes, UD100 USB DAC, Bose Companion II, Musical Fidelity HPA headphone amp, Bose Over The Ear
DandyCobalt
RE: Your system
Hi, the black slabs are granite worktop savers from Argos (about £13 each, if I remember).
The radiator is usually off (or very low setting), as the Pioneer plasma generates enough heat to keep the room cosy (very useful dual functionality from one device).
Concerning the corner set-up, my wife has forbidden me from moving to in front of the window and firing down length of room, so I've had to experiment to get the best sound.
I have found that the outer ring only of the B&W supplied bungs in the rear bass ports gives me best bass balance, and as my Kef subwoofer is in the corner behind the tv, I have added an Antimode bass equaliser (as recommended by many on this forum, thanks). It has substantially improved the bass definition, and sounds like I have a bass-player in the room now.
We had to check behind the tv to make sure that the bass player from our band wasn't actually stuck there and couldn't find his way out Smile
My job for today is to add a second Cyrus X Power in vertical bi-amping arrangement (while my wife is out at the shops). I'll post on how they sound with the CM8s.
I auditioned the CM8s against MA RX8s - the RX8s sounded better musically in the shop, but I can definitely say that the set-up I have now  (thanks again to the advice on this forum, and some experimenting) sounds better than the RX8s did.
The rosenut finish on the CM8s (and matching CM1s, CM Centre) plus the beautiful layout of the fronts by B&W has made it so much easier to get this type of kit into the house.
__________________
WishTree
WishTree's picture
RE: Your system
[quote=DandyCobalt
[/quote]
Hey.. Love the CM series.. I used to have CM7 (in maple) and then upgraded to CM9 (Piano black) with CMC (maple).. What a beauty these are.. especially in Rosenut (That is why I opted for Mahagony for the Proacs Cool)
How is the performance especially with Pioneer AVR? I am guessing they would be more detailed at top end. I like the way the speakers are brought forward to let them breathe in the room.
__________________
My System  |
HiFi: Oppo BDP-105 | Jolida JD-1501BRC | AG Strada | B&W 608 | Toshiba-46TL933G
HT: Sony BDP-S790 | Marantz SR6006 | Wharfedale DX-1 7.1 | Sony-55EX725
markiedee
markiedee's picture
RE: Your system
very slick setup dandy
__________________
Arcam A19 - Kef R100s - qed xt anniversary cables
DandyCobalt
RE: Your system
I've pulled the speakers as far forward and away from the screen as I can. There is a fireplace to the left.
I've been playing about with the toeing-in to get the best sound. I think they work best in my room with very little toeing-in, even thought the CM8 manual says to toe-in.
With the Cyrus and the Pioneer, the higher end is quite prominent, and I get good vocal and acoustic instrument definition - but that is how I like it (and my wife, fortunately) and bass is not a problem in the room. Just listened to the new John Renbourne album "Palermo Snow" and you can really hear all his finger/hand movements on the strings. Some might not like the natural "imperfections", but that's what it would sound like if he was playing in your living room?
I also have a rug and big settees etc in the room, which help with acoustics a lot.
For projection, I have to put a screen up in front of the whole lot, raised on some stools, which is not ideal, but the only way I can work it in a traditional English (small, with fireplace, windows etc) lounge.
__________________
DandyCobalt
RE: Your system
Great to hear that WHFSV are getting a pair of CM8s from B&W for review. Will be interesting to know what they sound like with the magazine's reference systems and compared to alternatives.
My second X Power should be up and running this afternoon, will post how bi-amped sounds later.
__________________
psycoschnauzer
psycoschnauzer's picture
RE: Your system
That's a nice set up you have there Dandy.  Congratulations.
I'd like to ask a question if I may.  Do the granite chopping boards improve the sound at all?  I ask this question, because I have a similar floor to yourself and wondered if it would make any difference.
I live in an eco-house, which has an unusual floor design - the floor is in fact suspended to make it more thermally efficient.  The downside is it tends to resonate.  Does anyone else have any advice about this at all?
Dave
DandyCobalt
RE: Your system
To be honest, I don't know, but based on these forums I have tried to add anything that might help the sound (some things quite expensive..like Cyrus pre/power amps...and some things quite cheap , like Argos granite chopping boards Smile . I've tried to improve all aspects of the sound, and used the cheapest alternative if I couldn't justify the price difference. For a piece of granite, the difference between the Argos £13 solution, and an audio specific solution, was quite large.
I've also gone for an Auralex Subdude beneath my subwoofer behind the tv (plus an Antimode s/w eq - definite significant improvement). However, had to wait about 4 months before the Subdude arrived in the UK!
__________________
byebyebaby236
byebyebaby236's picture
RE: B&W CM8
How do you find the centre channel is this setup?
I am thinking about the CM 8s myself but I am unsure as to what centre channel to get.
__________________
 27" iMac i7, 12 GB RAM + 27" ACD  iPhone 4 (32) Mac Mini + Drobo Media Centre + B&W MT 30 5.1 (PV1 Subwoofer) + Onkyo 609 + Sony Bravia Z465500 + PS3 +XBOX 360 + Apple TV (2nd gen)
DandyCobalt
RE: B&W CM8
The CM Centre is adequate for my setup and room size, plus the larger CM centre option is much bigger and would not fit in my rack. My one is the one that B&W have in their surround pack for the CM8s.
However, depending on how loud you need, and room size the bigger one might be better option.
__________________
reggaedave
reggaedave's picture
RE: B&W CM8
lovely setup, speakers look great.
__________________
Too many things to list but spent a fortune!
