Thunder creates the first in-ear headphones to use the Apple Lightning connection
The iPhone 7 is expected to be released in September and there's speculation that Apple will remove the 3.5mm headphone jack. One way to get around it would be to use wireless Bluetooth headphones, but some manufacturers, such as Audeze and Philips are turning to the Lightning port for a wired connection instead.
MORE: Apple Lightning headphones - everything you need to know
Thunder is one such company and has developed a pair of in-ear headphones that will use the port. Thunder claims they are the world’s first Lightning in-ear headphones to provide “high fidelity sound quality, active noise cancellation, battery-free charging and revolutionary sound customisation”.
Article continues below
The Thunder in-ears need to be used with the companion app, which adjusts the sound settings to best suit your ears by playing a series of notes at different frequencies and volumes and asking you what you can and can’t hear.
They also benefit from active noise cancellation and draw power from the iPhone’s Lightning port. There are two different modes: quiet mode to “completely” block out external sound and aware mode allows some ambient noise in. The in-ears claim to only use one percent of battery per hour.
Max Langridge
Max is a staff writer for What Hi-Fi?'s sister site, TechRadar, in Australia. But being the wonderful English guy he is, he helps out with content across a number of Future sites, including What Hi-Fi?. It wouldn't be his first exposure to the world of all things hi-fi and home cinema, as his first role in technology journalism was with What Hi-Fi? in the UK. Clearly he pined to return after making the move to Australia and the team have welcomed him back with arms wide open.
