Heed Obelisk Si mk2 + KEF LS50
17 replies [Last post]
Heisenberg
Heisenberg's picture
The two products are winners according to What Hi-Fi magazine; my question is if they sound any good together.  puzzled Any thoughts about this combo?
I already have the LS50s and am looking for a new amplifier to pair it with the speakers, with hopefully good effect.
TheHomeCinemaCentre
TheHomeCinemaCentre's picture
RE: Heed Obelisk Si mk2 + KEF LS50
Welcome to the forum. The Heed is dynamite and is well worth an auditon - I dont see any reason it wont work with the KEFs and produce excellent results but you have to listen to be sure the combination is right for you.
__________________
Nick
The Home Cinema Centre
plastic penguin
plastic penguin's picture
Heisenberg wrote: The two
The only way to know for sure is to listen to the combo yourself. Just because both are award winners it doesn't guarantee you'll like it.
__________________
Leema Pulse MKII-S; Naim CD5i MKII; Denon TU-260L MKII; MA RS6 speakers; Pro-ject Xpression 1; loads of different cables...
Formerly known as plastic penguin
Heisenberg
Thanks for the replies!
I'll have to check the combo for myself as you say, but still, I would appreciate any feedback from those who already had a chance to listen to it.
BTW, has anybody on this forum experienced any technical problems with the new Heed amp? I've been recently alarmed by some Heed users on another forum that the Obelisk amp produces audible noise in standby mode, and when you listen to a CD source for example, and happen to switch the input selector to a non-used input (while the CD is still playing), you can still hear the music coming from CD when you turn up the volume to 12.   :  Exclamation Mark
Are these problems a result of poor quality control (bad production run) or poor engineering ?
jjbomber
jjbomber's picture
I heard them in my local dealers and they were stunning. It was a jazz CD played on a Bryston CD player and it sounded like the lady was in the shop with us. Not sure what it's like with heavier sounds, but for pop and jazz, it will take some beating. I was shopping for something else and just walked into a demo. Absolutely stopped me in my tracks.
Heisenberg
I was worrying that the 35W might not be sufficient to drive the KEFs. Nice to hear that it isn't the case.
Now if only someone could confirm that the disturbing technical flaws described above aren't this amp's "standard features" pray
jcbrum
jcbrum's picture
I'm guessing, but I would think it's most likely to be poor engineering design.  They shouldn't do that.
JC
Heisenberg
JC
The question is, what should they do now?
Recall all faulty amps from the market?
jcbrum
jcbrum's picture
Heisenberg wrote:
JC
They might not know how to fix it.
You could try putting a shorting plug on the unused inputs.
JC
Heisenberg
JC
I was planning to use 3 or 4 of the inputs for different sources, but now I don't think it's a good idea as it seems that the inputs weren't implemented properly and there might be some interference between them.
I've just learned that when you turn off your source connected to the amp (while the Obelisk is still on), some hiss starts to come out from the tweeters. Any idea why that happens?
jcbrum
jcbrum's picture
Well, the hiss might have been there all the time, but be masked by a signal coming from the selected input.
However, if you think it wasn't, then it's probably caused by the input becoming unloaded.
It suggests to me that there are design inadequacies in the circuitry, possibly caused by ineffective de-coupling arrangements, or the generation of spurii, or an inappropriate selection of components, or maybe all three plus other reasons as well.
A good amp needs to be quiet, and is annoying when not so.
JC
jcbrum
jcbrum's picture
p.s. the above assumes your interconnect cables are ok, and not faulty.  Try removing the cable and see whether the hiss disappears.  -  JC
Heisenberg
I'm told that the hiss is still there even if no source is connected to the Obelisk.
Heisenberg
Is it true that you can't turn on/off the amp and switch the source with the remote?
There's no mention of that in the What Hi-Fi review.
Heisenberg
Thanks for the information, although it's pretty disappointing to hear. I hope that Heed will be able correct the design flaws ASAP.
jcbrum
jcbrum's picture
Hmmm, that might be problematical.  I think Heed make the amplifier under licence, and the amp's designer died from cancer last month.
JC
