Acoustic Energy launches NEO V2 budget speaker range
Acoustic Energy has unveiled the latest incarnation of its NEO loudspeaker range, called NEO V2.
The budget line-up, priced from £219 to £399 a pair, consists of the NEO V2 One standmounters (£219/pr), NEO V2 Three floorstanders (£399/pr), NEO V2 Centre (£179) and NEO V2 Subwoofer (£399).
The NEO cabinets have been updated with smooth edges, concealed magnetic grille fixings and new colour finishes – Vermont (walnut) or black.
Latest Videos From
Within, new crossovers feature high-quality polypropylene capacitors and air-core inductors on the high-frequency drivers resulting in "a faster and sweeter top end", claims AE.
Revised suspension and higher magnetic field strength on the low-frequency driver is intended to produce "tighter, more accurate bass".The LF drivers also use a twin Neodymium magnet assembly and long-throw voice coils.
The NEO One is a compact, two-way, reflex-loaded standmount speaker designed for smaller rooms or surround duties in a home cinema set-up.
While the NEO Three floorstander is a two-and-a-half way, reflex-loaded design capable of handling 170W RMS.
Both the One and the Three can be combined with the Neo Centre and Subwoofer to make up a 5.1 surround system. The Subwoofer is a fully sealed-box design with a 200W amplifier driving a 22cm driver with a 4.8cm voice coil and long-throw ferrite magnet.
Follow whathifi.com on Twitter
What Hi-Fi?
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
Read more about how we test
