Denon claims a world first with Audyssey DSX surround expansion technology
Denon's AVR-4310 AV receiver is equipped with Audyssey DSX and Dolby Pro-Logic IIz surround expansion technology
The company claims the AVR-4310 is the first AV receiver in the world to be equipped with Audyssey DSX surround expansion technology.
Audyssey DSX adds additional surround channels placed wider than the main front speakers, and two extra height speakers, to create a more enveloping and immersive soundstage.
This is in addition to Dolby Pro-Logic IIz, which also adds additional height speakers at the front of the room.
Impressive technical spec
The rest of the technical spec is equally comprehensive. There's support for fourth-generation Denon Link technology for reduced jitter transmission via HDMI; six HDMI inputs (one on the front) and two outputs; network connectivity; high-resolution video scaling; and Dynamic Volume control and Dynamic EQ.
A high-resolution 12-bit/10-bit scaler from Anchor Bay Technologies upscales standard resolution images to 1080p, and the AVR-4310 supports vertical stretch to display film content in its original CinemaScope aspect ratio.
Naturally, it will handle all the latest high-definition audio formats on Blu-ray.
Other familiar Denon audio and video technologies include the DDSC-HD Circuit, AL24 Plus Processing and Compressed Audio Restorer, plus Digital Noise Reduction.
The latest hi-fi, home cinema and tech news, reviews, buying advice and deals, direct to your inbox.
Network audio and photo streaming comes as standard, as do front and back USB ports with an iPod Direct Connect function, and multiroom support.
The Denon AVR-4310 will be available in silver and black from June for £1899.
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
