Yamaha DSP-AX863SE Subwoofer Output
Mon, Dec 29 2008, 5:03PM
Hi all,
Does this AV receiver, Yamaha DSP-AX863SE, has a passive subwoofer output? (ie. pre-amplified output for subwoofers that don't have inbuilt amplifier). Or if it doesn't, can anyone suggested a suitable amp in this price range/spec that would?
As I have two sub's, one is active and powered by it's on inbuilt amp and the other is passive, requiring an amplifier.
Thank you all,
Ben
- Login to post comments
I don't know of any A/V receiver which actually has a powered sub output. You're probably better off just using the active sub.
Failing that, if you're set on using both subs, you'll need a y splitter to allow two sub cables to be run from the single sub output on the 863, then a mono power amp amp for your passive sub. Balance and levels between the two subs may be tricky to regulate though.
Hi-Fi: Arcam A85, P85, CD192. B&W 602S3, PV1, Grado SR125, Atlas Titan, Hyper 2.0.
A/V: Sony KDL-V40A12U, BDP-S760, Humax Youview, Onkyo TX-SR875, B&W MT30 7.1, QED HDMI-P, S.A XT
