Chord Company upgrades its Active HDMI cable with ARC and Ethernet
New Active SilverPlus cable is High Speed certified, has audio-optimised Audio Return connection and Ethernet capability
The new version, which is officially called Chord HDMI Active High Speed with Ethernet (phew!), is fully certified as High Speed in all lengths – and it's available in runs of up to 15m.
As well as the new certification, it has an audio-optimised Audio Return Channel provision, Ethernet capability and an updated version of the in-line high-frequency filter used in the original Active HDMI. This is designed to remove HF interference, and thus give the best possible picture and sound.
Other changes include heavier-gauge silver-plated conductors, a third foil layer for better shielding, and die-cast plugs with heavy gold-plating, for better fit and connectivity.
The new cable is available in lengths of 1m, 2m, 3m, 5m, 8m, 10m and 15m. Prices start from £95.
Follow whathifi.com on Twitter
Join whathifi.com on Facebook
The latest hi-fi, home cinema and tech news, reviews, buying advice and deals, direct to your inbox.
What Hi-Fi?, founded in 1976, is the world's leading independent guide to buying and owning hi-fi and home entertainment products. Our comprehensive tests help you buy the very best for your money, with our advice sections giving you step-by-step information on how to get even more from your music and movies. Everything is tested by our dedicated team of in-house reviewers in our custom-built test rooms in London, Reading and Bath. Our coveted five-star rating and Awards are recognised all over the world as the ultimate seal of approval, so you can buy with absolute confidence.
