Removing Static
Fri, Feb 15 2013, 9:10PM
Hello, I have a pair of M-Audio Studiophile AV 40 speakers connected via the 3.5 headphone socket of my laptop to the phono L+R line in socket on the speakers. They are great sounding speakers but have found there is a lot of static on the volume knob and most times when I turn up or down it cuts out to one side and sounds really muffled.Is there any way of removing the static build up as it is really irratating me when I adjust the volume.
- Login to post comments
Are you sure it is static electricity, or is it more a crackle from the volume control? The latter is dust or dirt in the control and is a common problem in old or rarely used controls.
If they have been on a dusty table then I'd ask the dealer or MA what to do. Brave souls open up products and use airjets or switch cleaner, but I'd not do so without experience. Nervous types like me turn the kit off, unplug it all, then vigorously rotate the volume max to min repeatedly. Then reconnect and if you're lucky - problem solved.
Hi-Fi: Krell KAV-300cd, Michell TecnoDec/RB250/Grado Prestige Black1, KAV-300i amp, Transparent balanced interconnects and bi-wire to Sonus faber Concerto grand piano speakers, Nakamichi ZX-7 cassette deck, Logitech Squeezebox Touch, Hitachi FT-5500 and Sony S570ES tuners, BCD Engineering stand, RA Powerlink, Chord powerchord, Grado SR60i cans.
AV: Sony Bravia KDL-32EX503 telly, BDP-S370 player with QED HDMI. Currently unused: Denon AVR-1705, DVD-1710, KEF KHT1005.2
