Sennheiser RS 170 ear pads replacement.
4 replies [Last post]
axis
axis's picture
Hi All.
Im new here.
looking for help.
I have a pair of Sennheiser RS 170 headphones and im looking to replace ear pads ( letherette ones ) to velour ones, as the leather imitation is uncomfortable after long period due to sweat.
So my question is ? Would earpads from rs180 fit to rs170 model, looks very simillar to me.
thanks
Arek
caesar44
caesar44's picture
Yes, you're right..they are
Yes, you're right..they are very similar, but it looks like nobody have tried that. Why not try for yourself and let us know? or just email sennheiser requesting more info.
cscornette
cscornette's picture
RE: Sennheiser RS 170 ear pads replacement.
They have different part numbers.  For the RS 160/170, the ear pads are part # 534470, and for the RS 180, it's part # 534469.
The item description on www.headphone.com states that they are NOT interchangeable.  Quote from page:
"These pad cushions will NOT fit the Sennheiser RS160 or RS170 models. Earpad replacements for those two Sennheiser wireless headphones are sold separately here!"
Sorry.
axis
axis's picture
To all rs170 users,  180 ear pads ( velour ones ) fits perfectly to 170 model, much better experience over longer usage period. no sweaty ears Smile
CustomCable
CustomCable's picture
As said above the RS180 Velour pads fit fine on the RS170.
http://www.custom-cable.co.uk/sennheiser-replacement-rs180-velour-earpad...
Regards
__________________
Phil -  Custom Cable Service and Unilet Sound and Vision, South-West London
