Sony BDP-S790 Blu ray Player - Noisy Operation.
7 replies [Last post]
ChesterG
ChesterG's picture
I recently bought a BDP S790 bluray player and while the picture and sound are great the unit itself is quite noisy when playing the discs, much noisier than my old Sony DVD player was. I've read a couple of similar observations online about the S790 so is it just a common aspect of this model?
__________________
Rotel 1520.....B&W 684.....Arcam CD192.....RPM4 Turntable
f1only
f1only's picture
RE: Sony BDP-S790 Blu ray Player - Noisy Operation.
I havn't found my unit noisy except with the initial load up, but that is only to be expected with faster loading times. I did rest my remote control on the top of it once & it buzzed when loading, overall though i am very happy with it.
If it is noisy all the time i would suggest you ring the supplier & ask if they will take it back for an exchange if possible.
Regards ..
Papalazarou75
Papalazarou75's picture
Sony Players are known to be noisey, both the 380's i have are noisey as hell with some discs.
ChesterG
ChesterG's picture
I suppose I'll get used to it, in time.
__________________
Codex77
Codex77's picture
I haven't found mine to be particularly noisy, at all...
__________________
Sony Bravia KDL-46HX853 3D smart TV, Yamaha RX-A2010 AV receiver, Monitor Audio Silver RX6 floorstanders, Monitor Audio Silver RX Centre, Wharfedale Valdus 100 SE bookshelf speakers (surrounds), Sony BDP-S790 blu-ray player, Sony Playstation 3 (500Gb).
motley
motley's picture
My BDP S770 is noiser playing Blurays than DVD's which I understand is due to disc speed, but it has been dramatically improved by putting 4 very soft wiring gromets under the feet.
ChesterG
ChesterG's picture
Thanks for the info. I'll try experimenting with various items under the feet to see if they make a difference.
__________________
Papalazarou75
i put mine on 4 1 inch foam blocks,it certainly did help , not perfect but better ,just certain discs (mainly rental) were really noisey.
to be honest ,that player was cheap from argos £69 each so i was not too fussed - but the silience from the Panasonic is golden Smile
