3D Audio
8 replies [Last post]
TWARDLAW
TWARDLAW's picture
Is anybody able to tell me, is there an reasonably priced HDMI splitter on the market that will enable me to send a 3D signal from my PS3 to a 3D enabled TV whilst at the same time sending a full HD audio signal on the second HDMI output to my Sony STRDG820 receiver amp. I am more than happy with this Amp unit and do not want to upgrade it at this time, but cannot seem to find a splitter which will give me Dolby tru-hd and DTS Master Audio without an amp upgrade.
bearwolfblade
bearwolfblade's picture
RE: 3D Audio
Something like this perhaps http://www.amazon.co.uk/Neet%C2%AE-SPLITTER-Amplifier-Display-Shipping/d... .p.s the amplifier should have hdmi out which means you dont need a splitter just another hdmi cable.
__________________
ONKYO C-S5VL / ONKYO TX-8050 / MONITOR AUDIO RX2
bigboss
bigboss's picture
RE: 3D Audio
You cannot separate an audio signal from a video signal with an HDMI splitter.
The cheapest option is to buy a blu-ray player with twin HDMI outs, like this one: http://www.amazon.co.uk/dp/B004QWY7SO/ref=asc_df_B004QWY7SO4690369?smid=...
You won't have to upgrade your receiver then which is a far more expensive option.
__________________
bearwolfblade
RE: 3D Audio
The cheapest option is to buy a blu-ray player with twin HDMI outs, like this one: http://www.amazon.co.uk/dp/B004QWY7SO/ref=asc_df_B004QWY7SO4690369?smid=... You won't have to upgrade your receiver then which is a far more expensive option.
what are you on .all they need is a second hdmi cable so they can connect the playstation 3 to the sony amplifier and then connect that amplifier to the television like any home cinema system .try reading the problem first before giving out expensive incorrect advice in future
__________________
bigboss
bigboss's picture
RE: 3D Audio
What are you on about? Have you read the OP's question properly? The OP wants HD audio with 3D & wants to split audio & video signals.
HDMI splitter you've suggested does not meet his requirements. They're suitable if you want to toggle between a TV & a projector for example. They cannot separate audio from video signals.
PS3 has sacrificed HD audio for 3D: http://www.psuni.com/sony-sacrifices-lossless-audio-for-ps3-3d-blu-ray-p...
If you want 3D & HD audio, you need a separate blu-ray player like the one I've suggested.
__________________
bearwolfblade
RE: 3D Audio
HDMI splitter you've suggested does not meet his requirements. They're suitable if you want to toggle between a TV & a projector for example. They cannot separate audio from video signals. PS3 has sacrificed HD audio for 3D: http://www.psuni.com/sony-sacrifices-lossless-audio-for-ps3-3d-blu-ray-p... If you want 3D & HD audio, you need a separate blu-ray player like the one I've suggested.
you said you cant split audio/video but then change your mind saying you can if you use the panasonic which only has 2 hdmi you need 3 hdmi to split a/v 1 cable in 2 cables out .they didnt know their sony amplifier has a hdmi out on it and i own the panasonic if theres no full hd sound coming in from the ps3 your not getting hd sound at all and not only that you cant play 3D ps3 games on a blu-ray player
__________________
professorhat
professorhat's picture
RE: 3D Audio
The Panasonic Blu-ray player linked above has two HDMI outputs - you connect one of these outputs to your TV to send 3D pictures direct, and the other HDMI output to your AV receiver to send the HD audio direct. So only two HDMI cables are required for this and it's one of the simplest methods of getting 3D if you don't have a 3D compatible AV receiver.
On the splitter question, whilst theoretically it should be possible for a 1.4 certified splitter to send the signal to both the TV for 3D and the amp for HD audio, I wasn't aware that there were any which had in fact been certified to do this. All the tests I've seen other people perform so far have indicated it's not possible, but happy to be proved wrong on this as I've done no actual testing myself.
I was under the impression that a new update for the PS3 now allowed 3D and HD audio to be sent to a compatible receiver (source here and here), but I've not tested it myself. As noted above, with only one HDMI output, I believe you would therefore need a 3D compatible receiver for this to work.
bearwolfblade
RE: 3D Audio
isnt that what i said in my first reply using the op's Sony STRDG820 3D receiver amp with a second hdmi cable banging head against wall
__________________
professorhat
RE: 3D Audio
The Sony STR-DG820 isn't a 3D capable receiver. You may be thinking of the newer Sony STR-DH320.
