Powerline adapters - How successful or reliable?
6 replies [Last post]
gowiththeflow
gowiththeflow's picture
Not Wi-Fi as such, but related.
We've found Wi-Fi to be a bit flakey in the far reaches of our home. Certainly not reliable enough for video streaming etc.
I'm considering using Powerline adapters, but would like to know how successful these are, particularly when being used on different ring mains.
In this house there are 4 different ring main circuits for wall sockets etc, so with the only connection between them being at the consumer unit, behind the isolator switches and RCD protection, will the signal be significantly attenuated or even blocked ?
michael hoy
michael hoy's picture
RE: Powerline adapters - How successful or reliable?
Didn't work for me, tried three different makes.
My equipment is in the loft and the devices just will not talk to each other.
__________________
AV System -  Panasonic 42VT30 ¦ MA Apex 5.1- 4xA10 1xA40+ AW-12 Sub ¦ Van Damme UP LCOFC Speaker Cable ¦ Pioneer SC-LX85 ¦ OPPO 95 ¦ Mark Grant G1500HD Precision audio cable ¦ Sky+ HD(1TB) ¦ Chord Active HDMI ¦ Belkin PF50 mains conditioner.
Bedroom - Sony KDL-40W2000 + Archos 7 streaming from Windows Home Server 2011, Altec Lansing inAir 5000.
Dining Room - Sonos S5.
Music - HP Proliant Server running WHS 2011 ¦ streaming FLAC to Sonos ZP90 and OPPO 95 via SC-LX85.
Hi Fi - Cyrus 8 XPd QX amp ¦ Cyrus PSX-R power supply acting as Pre Amp ¦ Quad 909 Power Amp ¦ Speakers - Spendor A3 ¦ Logitech Squeezebox Touch upgrade by Fidelity Audio ¦ power supply upgrade by Mains Cables R Us ¦ Power Plant Premier mains regenerator.
Controlled by – iPad2 and Harmony 1100.
baldywig
baldywig's picture
i run 4 all round the house, superb performance, i bought an extra one due to the speed being higher with these than a 15m cat 5 , i got the devolo a/v 200,s, 2 minutes to set up but make sure its direct to mains & not through an extension.
Tartan Man
Tartan Man's picture
From a personal point of view and with experience I would say the Powerline adaptors are a great thing. I currently have a set up of Devolo AV 200 running around my house which I find brilliant. My house has got solid internal brick walls which can prove a nightmare if using wifi. My Devolos are around 3-4 years old and have never let me down. The speeds are lightning fast (just about the same speed as comes into the house). Since I bought mine things have advanced further with Devolo Wireless extenders and multi output adaptors which might be even better for your setup.There's other good manufacturers as well so it might be worth checking Netgear,Advent,etc. Hope this helps.
Regards
Tartan Man
__________________
If I Wasn't Here I'd Be Somewhere Else!!!
Kef R 700 Floorstanders, Kef R 600 Centre, Kef R 800 Dipoles, Paradigm Studio 12 Subwoofer, Anthem MRX 700 AV Reciever, Panasonic 50" VT50, Panasonic BDT-500 Blu-Ray Player, BDI Ola AV Cabinet, Mede8er 2tb Media Streamer,Playstation 3, XBox 360 and Sky HD
gowiththeflow
Thanks for the replies so far.
My main concern is using them across different electrical circuits. As I said in my original post, there are 4 separate ring circuits for the sockets. I'm looking to send from a socket on one circuit, to another on a separate circuit at the other end of the house, up two floors (attic bedroom in an extension).
There is no electrical connection between the different circuits, except back through the consumer unit. Can they work effectively across the divide, if at all?
If I go ahead, I'll be getting Devolo units. The 550 Mbps range of adapters has now been expanded, however the 200 Mbps range does include a wireless N repeater complete with 3 ethernet ports. Mix and match is likely.
pwiles1968
pwiles1968's picture
I use 2 across completelyp separate circuits in the house, the consumer unit is the only connection the work well for AirPlay etc.
__________________
Stereo -1st Gen Apple TV with ATVFlash & 1TB HDD > Audiolab CDQ > Bel Canto Evo 2 > B&W 805s
davejberry
davejberry's picture
Mine do, and they are the devolo AV200+ with the integral sockets. Getting about 150 to 160 Mb. Use for streaming audio and online gaming. as have  concrete walls and floors and wifi is rubbish ouside of the lounge where my router is.
__________________
LOUNGE: SONY KDL-46W4000; STR-DA2400ES & BDP-S350; SKY+; TOSH SD3010 DVD; PIO PD-F1009 MULTI CD; WII; KEF CRESTA 2 fronts,CRESTA 1 rears CRESTA CENTRE; BUDGET INTERCONNECTS & 79/42 STRAND OFC SPEAKER CABLES    BEDROOM: PANA TH42P-WD6;
