3 posts / 0 new
Last post
admin's picture
Last seen: 2 days 9 hours ago
Warbling Bush MTT1
It sounds as though something is causing the rotational velocity of my Bush MTT1's platter to increase then decrease once per revolution.  The effect is a slight but noticeable warbling.  Anyone got experience of fixing this sort of issue?  I haven't yet pulled apart the central spindle as I'm not sure if I'll be able to put things back together afterwards.
 Apologies if this is a trivial issue; I'm fairly new to the world of vinyl.
 Cheers,
 Will
Anonymous's picture
Re: Warbling Bush MTT1
Could it need a new belt?
Amyl Right Mate's picture
Last seen: 3 years 11 months ago
Just to eliminate the possibility of a record with an off-centre hole, is the effect apparent with every record you play?
Log in to post comments
